Old 10-24-2006
pod4477 pod4477 is offline
Senior Member
pod4477 has a reputation beyond reputepod4477 has a reputation beyond reputepod4477 has a reputation beyond reputepod4477 has a reputation beyond reputepod4477 has a reputation beyond reputepod4477 has a reputation beyond reputepod4477 has a reputation beyond reputepod4477 has a reputation beyond reputepod4477 has a reputation beyond reputepod4477 has a reputation beyond reputepod4477 has a reputation beyond repute
EQ help
hey guys what does the terms, scooping and rolling off mean in eqing?
Old 10-25-2006
rayc's Avatar
rayc rayc is offline
L'ancien escargot
rayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond repute
Scoop? - cut the mid in a smilie curve
Roll off? - graduated decrease (soft or hard knee?) &/or competitive preparation of greyhounds pre jam.
Cone? - prerecording sedative or pre jam incentive
peak? - when the scoop that was in the cone is about to roll off
EQ? - Elastic Quotient - how far you can stretch the stuff you scoop into the cone to get to a peak before you roll off the couch & have to go & get some more.
Question: which of the above, if any, approaches being vaguely acceptable as a definition?
Answer: What?
Cheers
rayC
soundclick, unearthed, mspace & utub
Old 10-25-2006
sirslurpee sirslurpee is offline
What does THIS button do?
sirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond repute
Answer: What?
WRONG you didn't question in the form of an answer........
Old 10-25-2006
Kevin Deschwazi's Avatar
Kevin Deschwazi Kevin Deschwazi is offline
Brittunculus
Kevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond repute
First pic is scooped frequencies, second pic is rolled off frequencies:
"Just give the great unwashed a pair of oversized breasts and a happy ending, and they'll 'oink' for more every time."
C. M. Burns
http://www.shuttleworths.co.uk/micloop.gif
Old 10-25-2006
daav's Avatar
daav daav is offline
Flailing up a storm.
daav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond repute
nice illustrations Kevin.
To help put in perspective, 'scooped mids' is pretty much the definition of the metal tone that started in the late 80s with metallica and a number of other bands. they would EQ out the midrange, and it would produce this hollow sounding distortion that kind of hit you in the chest and felt like it was lowering the air pressure in the room or something. Very cool effect until everyone in the world seemed to be doing it and it became blasse.
Some people scoop the mids out of some things like kick to make room for the tracks that typically live more in that range, like guitars and vocals and keys. This is a matter of taste and opinion.
The "roll off" can happen at eitehr end of the spectrum, a low end roll off is usually used for tracks that don;t need a lot of that frequency, like guitars- generally rolling off soemof the low frequency stuff on guitars removes some of the muddiness you can get, and that low end is usually replaced with kick and bass. You might roll off the high end on the bass and kick for the same reason as well.
there is also high pass and low pass, high pass will let everything higher than a specified frequecy through, but kill everyhting below it and vice versa. the only real difference here is that the roll offs tend to be more gradual.
Daav
