New DSD recorders from Korg..
Tascam has upgraded their Portable DSD Machine, (The DV-RA1000) with the addition of a Hard Disk. This is a big advantage over the DVD drive on the first one..swapping discs is a pita.
http://www.korg.com/gear/info.asp?a_...&category_id=3 ![]() ![]() ![]() Future-proof digital recording is here With the pristine fidelity and ultimate flexibility of 1-bit technology, the new, surprisingly affordable MR-1000 and MR-1 ensure that your final mixes and location recordings are never obsolete. Uncompromising, future-proof fidelity at an unprecedented price Korg’s new, super-portable MR Professional Mobile Recorders break new ground by providing high fidelity 1-bit recording technology at unheard of low prices. The hand-held MR-1 provides high quality 1-bit/2.8 MHz recording and playback, while the mobile/tabletop MR-1000 delivers an astonishing 1-bit/5.6 MHz, doubling industry DSD recording quality standards. Powerful new software bundled with each MR recorder enables the conversion of your 1-bit recordings and mixes into all of today’s audio formats without degradation. Best of all, by archiving your data in 1-bit format you’re ready for the future, as playback systems and standards change. The MR Professional Mobile Recorders are ideal for source recording, podcasting, broadcast journalism including ENG/EFP, as well as archiving final mixes and master recordings. 1-bit technology equals pristine fidelity 1-bit recording is the latest advancement in audio, and has been adopted for use in the critically acclaimed SACD recording format. It offers a frequency response of DC to 100 kHz and dynamic range of 120 dB. This uncompromising fidelity, low noise floor, extended dynamic range, lifelike imaging and analog quality depth has been praised by top experts. But there are other important advantages to the format that are of benefit to all recording professionals, regardless of their tracking platform. Future proof flexibility Today’s state-of-the-art 24-bit converters use high-speed 1-bit conversion to capture audio, using real-time decimation and other processes to present the data in the desired bit depth/sample rate format. The beauty of the MR’s bitstream format is that it uses the original 1-bit data, without the need for the other processes. What comes in comes out, with no manipulation needed. As files are converted and reconverted between various bit depths and sampling rates, there are possibly degrading effects, depending on the sample rate conversion algorithms. The critical issue is that files mixed and mastered in today’s state of the art resolution may be insufficient for tomorrow’s formats. Archiving your final mixes and masters in a 1-bit system allows you to bypass these issues, and preserve your music with both the highest fidelity and in a more “universal” format. That data then can more easily be converted at a later date to the bit depth/sample rate format of your choice without compromising the integrity or fidelity of the data. You can even convert to newer formats that will be adopted in the future, be they multi-bit or a further migration to the 1-bit format. Free integrated software solution Both MR recorders come with Korg’s innovative and powerful AudioGate™ software for Mac® and PC. AudioGate can convert 1-bit recordings into WAV and AIFF formats at various bit-rates (and vice versa) and offers real-time conversion and playback of 1-bit files. It also does essential functions like DC offset removal, gain control, and fade in/out. The combination of these recorders and this exclusive software makes the perfect system for both capturing and preserving your critical projects and source recordings. This archiving capability that had only been the domain of the major record companies and top studios is now available for everyone! Real world features Each recorder supports multiple recording formats including DSDIFF, DSF, and WSD 1-bit formats, as well as multi-bit PCM format (BWF) with resolutions up to 24-bit/192 kHz. They both feature internal 20 Gbyte hard drives for ample recording times, and USB 2.0 connection for fast and easy transfer of files between the recorder and your computer. MR-1000 The MR-1000 is the perfect tool for the professional who wants to record and archive their final mixes in the studio, while its compact size and portability make it ideal for location recording. Whatever the use, you get the benefit of capturing it at the new high 5.6 MHz rate. After recording and editing all your tracks in the DAW/hardware system of your choice, you can mix directly, or via an analog summing mixer, to the MR-1000. This gives you the superb fidelity of high-rate1-bit technology, which when transferred to your computer can be converted to the mastering format of your choice thanks to AudioGate. And backing up in 1-bit format “future proofs” your mix for potential reuse in the future. MR-1000 Back Panel The table-top MR-1000 includes combination XLR/ 1/4" input connectors with top quality microphone preamps, phantom power and built-in limiting. Both XLR and RCA outputs are provided for maximum flexibility. High speed USB connectivity allows easy file transfer to and from a computer. The MR-1000 runs on AC power or via AA batteries for mobile freedom. MR-1 The MR-1 is the ultimate portable 1-bit recorder, perfect for location recording, broadcast journalism, live music performances – even for rehearsals and song-writing sessions. By recording in 1-bit/2.8 MHz format you are assured that your most important, once-in-a-lifetime moments are captured in stunning detail, and ready for whatever the future brings you. And back in the studio it also provides superb final mix and archiving benefits. MR-1 Top and Side views and stereo electret condenser mic. The ultra portable MR-1 includes dual balanced mini plug inputs and a stereo mini plug output. It includes a stereo electret condenser mic so the unit can be tucked away and the mic clipped or placed in a convenient location. High speed USB connectivity allows easily file transfer to and from a computer. The MR-1 runs on AC or long-life rechargeable lithium polymer battery. Future Proof Recording Explained For a complete overview of current PCM digital audio techniques and some of the principals and advantages that 1-bit recording provides, both in terms of fidelity and archiving for future use, read Future Proof Recording Explained. Specifications subject to change without notice
http://www.capitolflags.com/images/c...ebel-small.gif |
| Completely MIDI CONFIG Illiterate | Outhabox | MIDI Mania | 4 | 03-10-2006 10:43 |
| DSD Primer | BigRay | Recording Techniques | 0 | 01-07-2006 10:39 |
| DSD Vs PCM from the Head Engineer at Phillips | BigRay | Other Equipment and Reviews | 0 | 12-08-2005 09:00 |
| Fostex vs. Yamaha vs. Korg digi recorders | ACIDBANDIT | Other Equipment and Reviews | 8 | 06-13-2004 12:23 |
| Korg HDD Recorders vs others | Huaxtec | Other Equipment and Reviews | 47 | 03-11-2002 15:16 |
