Old 10-21-2006
Newbie dude Newbie dude is offline
Dedicated Member
Newbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond repute
micing the bass drum
Okay, tomorrow I'm going to be recording a drum track, and I'm gonna have to use a studio projects b1 condenser mic. How should I go about micing the bass drum.
Also, today, I noticed when some plays a bass drum, air shoots out of the whole. So I assume I either need to use either a pop filter or a foam mic condom, cause won't the wind damage a condenser? Which should I use? And should I use a 10 db or 20 db pad? or no pad at all? A post before 3 tomorrow would be appreciated.
Old 10-21-2006
Track Rat's Avatar
Total Gear Slut
The best advice I could give you is to find a dynamic mic. Any dynamic and put it inside the kick pointed at the beater. Then take the B1 and point it at the front resonent head (NOT near the hole!!) maybe 2 -4" away. You probably don't have to worry about flipping phase on one of them. I've never found it necessary.
Mike
Old 10-21-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Normally, you don't use a large diaphragm Condenser on a kick, at least not alone. You would be better off with a 57 inside the drum and, if you have to, put the LDC a few feet away from the kick.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 10-21-2006
Dedicated Member
alright, well, tell me these. Would it be better to have the b1 on the snare and a 57 on the bass drum, or the b1 on the bass drum and the 57 on the snare?
Old 10-21-2006
surfmaster's Avatar
surfmaster surfmaster is offline
sitting in your backseat
surfmaster has a reputation beyond reputesurfmaster has a reputation beyond reputesurfmaster has a reputation beyond reputesurfmaster has a reputation beyond reputesurfmaster has a reputation beyond reputesurfmaster has a reputation beyond reputesurfmaster has a reputation beyond reputesurfmaster has a reputation beyond reputesurfmaster has a reputation beyond reputesurfmaster has a reputation beyond reputesurfmaster has a reputation beyond repute
make a kick tunnel with cushions and blankets out a couple of feet with the mic at the end of the tunnel. this is the only way i have ever gotten a LDC to sound good on kick.
tascam 1804
self-built amd 4000+ system
gateway m285-e core 2 duo tablet pc
m audio sp-5b's
reaper v1.8x
Old 10-21-2006
Dedicated Member
umm...the bass drum has some sort of pillows and blankets in it.
Ok, I have a 57 and the b1, and I just remembered I have a cheap 20-30 buck dynamic mic.. I need to do a take of just the bass drum and the snare. What should I do?
Old 10-21-2006
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
You only have a few options. Try them all and go with what sounds best.
Old 10-21-2006
Dedicated Member
Well, normally, thats what I'd do, but if micing the bass drum with the condenser is gonna rruin my mic, then I'd kinda perfer not to even try it. So, thats why I'm trying to figure out if it will. Plus, it'd just be nice to know your opinions. I have limited time with this band time
Old 10-21-2006
punkin's Avatar
punkin punkin is offline
Univalve & Avatar Speaks
punkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond repute
I've had good results with my MXL V69 on kick. I put it about 3 feet out front maybe more, about a foot off the floor off center from the drum about a foot and pointed at the edge of the kick drum rim. With a set up like this I like to go minimalist, 2 OH's in X/Y, maybe one on the snare and the LDC out front. Don't think of the LDC as a kick mic perse' but rather a center room mic with the added SPL of being out front.
Like one of the other posters said, DONT put it in front of the hole unless you're ready to throw it away. EQ will be your friend and if you can, isolate the mic from the support device, the thumping can get to the mic and make all kinds of noise. It can work but it would be best if you had something else to support the sound. A condenser inside would be nice.
She's not the boss of me
Old 10-21-2006
dwarf's Avatar
dwarf dwarf is offline
Pok'e'mon master
dwarf has a reputation beyond reputedwarf has a reputation beyond reputedwarf has a reputation beyond reputedwarf has a reputation beyond reputedwarf has a reputation beyond reputedwarf has a reputation beyond reputedwarf has a reputation beyond reputedwarf has a reputation beyond reputedwarf has a reputation beyond reputedwarf has a reputation beyond reputedwarf has a reputation beyond repute
OK I havn't done much drum micing, but this is what I'd do
Sm57 on bass
B1 as a mono overhead (allthough lower closer to the snare)
Cheap dynamic on snare, as close as possibal without causing clipping.
Just my $.02
The leprichaun tells me what to do
and soon he will tell you too
Old 10-23-2006
Janesaid2me Janesaid2me is offline
Senior Member
Janesaid2me is a jewel in the roughJanesaid2me is a jewel in the roughJanesaid2me is a jewel in the rough
Not sure what you ended up doing, but idk, using a condenser on a kick drum seems silly to me....obviously you cant go out and buy urself an appropriate mic for kick drums, or else i assume you would....so with the three mics people have been talking about i would
1. Use either the 57 or the other cheapy dynamic mic on the bass drum...see which sounds better (or which is better on the snare and use the other for the bass)...place it about half way into the bass drum angled down and away from where the snare would be towards about where the beater hits.
2. Now which ever dynamic mic you decided not to use on the bass drum use on the snare. Stick it about an inch or two off the head pointing down at a 45 degree angle kinda towards the drummers crotch...haha.
3. Use that b1 condenser as an mono overhead....stick it in the middle of the set (this usually is not a straight line through the kick drum but more of a diagonal line)...stick it about a foot-2feet about cymabals....ummm yea
so thats it for now...im sure u already did the recording but maybe this will help for next time.
New Rep Point Thread. DJL Prime Time 114420 7 Hours Ago 17:19
A Bass Drum Tunnel? Hubbawho Drums and Percussion 6 06-08-2005 11:27
Bass Drum and Bass Guitar Fighting Robertt8 Mixing / Mastering 5 11-09-2004 09:08
Whats the best Bass drum mic for recording bass guitar? Mongoo Microphones 8 02-20-2004 01:22
How do I remove bass drum from overheads? guitarsg1 Recording Techniques 3 03-25-2002 20:45
