Old 10-21-2006
random effect random effect is offline
Junior Member
random effect will become famous soon enough
just got my sp vtb1 preamp.. questions
the preamp seems to be just fine for vocals but it makes the guitar sound very harsh when im using distortion. i tried messing with mic placement and the tube blend but i can't seem to get a good distorted guitar sound from it. I'm micing a marshall halfstack with a shure sm57 and running through a 3630 comp into the preamp. should i reverse the order of pre and comp? any tips on the gain staging in the preamp? It just sounds really harsh and brittle. thanks guys
Old 10-21-2006
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
If you're going to use the compressor (personally, I'd advise against it), it should be routed as an insert, via the insert point on the vtb-1. The compressor is expecting a much hotter signal than is produced by your mic. Take the compressor out of the chain entirely, and I'm guessing your sound will improve.
"That was so terrible, I think you gave me cancer!"
My tunage
Old 10-21-2006
Junior Member
yea i just tried that actually right before you posted and it's still really gritty sounding... I know a tube pre adds some balls but this sounds a little too rough. I backed down the tube blend to ss and it still has some strange breakup in the high frequencies
Old 10-21-2006
Micter's Avatar
Micter Micter is offline
No Title
Micter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond repute
Where are you placing the mic? It seems as though you might be over the voice coil. Try putting it between the voice coil and the edge.
Live Clean and Play Dirty
Old 10-21-2006
Junior Member
i've tried it right at the cone and that was very brittle sounding and then i tried it closer to the edge and it was a little better but lacked clarity. i bypassed the pre and there wasn't any harshness but the signal waS A LOT weaker
Old 10-22-2006
orksnork orksnork is offline
Force of Nature
orksnork has a reputation beyond reputeorksnork has a reputation beyond reputeorksnork has a reputation beyond reputeorksnork has a reputation beyond reputeorksnork has a reputation beyond reputeorksnork has a reputation beyond reputeorksnork has a reputation beyond reputeorksnork has a reputation beyond reputeorksnork has a reputation beyond reputeorksnork has a reputation beyond reputeorksnork has a reputation beyond repute
well...it wasn't amplified.
Old 10-23-2006
Junior Member
yea i gathered this much. Im just saying that it sounded much smoother but i can see the benefits of the tube in how punchy and clear the sound is when used.
MIXER vs. PREAMP (low end) ---3 questions! Thank You! Mr Music Newbies 2 03-06-2006 20:19
Preamp for Marshall MXL V57M? crossroads Newbies 1 12-30-2005 16:53
preamp comparison Peetr3 The Rack 62 12-28-2005 17:01
preamp vs. dynamic mic jungkang Microphones 7 08-02-2001 21:10
sound card preamp versus real preamp zoetrope Microphones 24 07-16-2001 07:32
