Old 10-19-2006
BodieB BodieB is offline
Newbie
BodieB is on a distinguished road
clicking noise while recording
Any ideas? Help? I installed a new MAudio soundcard to record (playback with soundmax through my desktop speakers) I use a Behringer ub802 and an AKG perception 100 mic. I have tried adjusting about every parameter in the Maudio control panel, but no luck. I have a 1yr old Dell dimension that works great for every other application. Recording works ok if I use the original soundmax card.
Old 10-19-2006
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
Which driver are you using for the M-Audio card?
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 10-19-2006
Newbie
Driver
Hi Mr. Guy,
thanks for the response; driver is 5.10.00.0052
Old 10-21-2006
littledog's Avatar
littledog littledog is offline
Three Thousand and Counting
littledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond repute
I don't know anything about any of the gear you have.
But in general, if you are recording digitally and keep getting sharp intermittent clicks, it is usually a clocking problem, at least if you have two or more pieces of digital gear in the chain.
All pieces must run off of the same digital clock, or else the samples get misaligned as the individual clocks drift apart, resulting in the sharp clicks.
If your setup has only one piece of digital gear, then it must be something else. I would call M-Audio tech support and describe your problem. Chances are it is something they have seen before and they will be able to instantly tell you how to eliminate the issue.
Old 10-22-2006
legionserial's Avatar
legionserial legionserial is offline
Dead
legionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond repute
What hard drives are you using? And what mothoerboard are you using? I recently had a similar problem with a Delta 44 that ended with me having to switch from SATA to IDE because of the SATA chipset on my motherboard.
"Introduce a little anarchy. Upset the established order, and everything becomes chaos. I'm an agent of chaos.
Oh, and you know the thing about chaos? It's fair..."
Old 10-22-2006
montage's Avatar
montage montage is offline
Senior Member
montage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond repute
Do you have both new and old sound cards installed? Because of IRQ conflicts, I had to disable the old card, and move my Delta1010LT to an acceptable slot before it played OK with all the apps.
Old 10-22-2006
gummblefish's Avatar
gummblefish gummblefish is offline
Twitchy Wanker
gummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond repute
Is it a latency problem? Check the sound cards Latency in settings.
"Sorry wont Suture My Colon"
Computer recording noise sprogdw Digital Recording & Computers 3 04-07-2006 19:51
noise while recording (mic problem ?) dead_man Microphones 0 08-19-2004 01:05
Noise in recording the voice ashras99 Recording Techniques 0 08-17-2004 14:31
Recording level noise Gavin Digital Recording & Computers 9 10-14-2003 12:10
