Old 10-17-2006
crazyjman's Avatar
crazyjman crazyjman is offline
Self proclaimed man-whore
crazyjman has a reputation beyond reputecrazyjman has a reputation beyond reputecrazyjman has a reputation beyond reputecrazyjman has a reputation beyond reputecrazyjman has a reputation beyond reputecrazyjman has a reputation beyond reputecrazyjman has a reputation beyond reputecrazyjman has a reputation beyond reputecrazyjman has a reputation beyond reputecrazyjman has a reputation beyond reputecrazyjman has a reputation beyond repute
ez drummer and sonar 4pe
I wonder if anybody could help me with this. when I load ez drummer as a dxi effect I can play with the drums and listen to the grooves fine, but when I drag a groove onto the track and play it I hear nothing. I figured it must be something to do with the midi settings however this is not my area of expertise.
Old 10-17-2006
Dogman's Avatar
Dogman Dogman is online now
Campeón de la Internet
Dogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond repute
I have 5PE, and I set up the midi track output to a drum map called ezdrummer. My always defaults to the soundcard, so I have to change that everytime I load up ezdrummer. Hopefully it's something that simple for ya.
I won the internets......
Old 10-17-2006
Crumbles Crumbles is offline
Banned
Crumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond repute
ez is a drummer?
Old 10-17-2006
crazyjman's Avatar
I'll try that, thanks
Old 10-17-2006
Dogman's Avatar
Originally Posted by watermelon
ez is a drummer?
Actually, he is...didn't you see the video?
Hope that works for ya Crazy.
Old 10-17-2006
dirtythermos dirtythermos is offline
Dedicated Member
dirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond repute
Be sure you drag the MIDI clips into the MIDI track, not the audio track. I have made that mistake several times.
Do you have drum maps? If not, there's a link on my blog to maps for the standard and cocktail kits.
Third Take a blog about home recording
Old 10-17-2006
crazyjman's Avatar
that's funny that you said that because I just realized that I have to put ezdrummer as a fx on an audio track in order for it to come up as an output on the midi track.
Thanks for the help guys........
........however could you help with just one more question?
If i'm using my keyboard to enter drums to the piano roll, how can I do this in real time (jam on my keyboard to create drum tracks)? I'm noticing delay when I try to do it. Is this a latency issue or a midi config?
Old 10-17-2006
crazyjman's Avatar
Thanks for the drum maps too! That kicks ass
Old 10-17-2006
travelin travis travelin travis is offline
Banned
travelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond repute
it's a latency issue. i usually keep my latency around 256 samples (about 6ms) when playing midi drums. 512 samples (about 12ms) works too but it kind of messes with my head. this is at a sample rate of 44100. you normally have to make the changes in your sound card's application but i think you can make the changes within sonar.
it's been awhile since i've seen sonar but i think it was under options, audio....
Old 10-17-2006
crazyjman's Avatar
Thanks for the help. I'm on it!
Using PA9 Session drummer with Sonar xl2.0 Toki987 Cakewalk / Sonar Forum 0 08-14-2002 08:56
Session Drummer PA9, Slicy in Sonar XL Toki987 Cakewalk / Sonar Forum 0 08-13-2002 08:12
Drummer using Sonar CC737 Cakewalk / Sonar Forum 2 04-05-2002 17:11
Sonar and Drag and Drop Drummer Problem marksman Cakewalk / Sonar Forum 0 03-19-2002 19:14
Sonar (drag and drop drummer) not there? Flash Cakewalk / Sonar Forum 11 02-01-2002 18:00
