Old 10-16-2006
thomaswomas thomaswomas is offline
Junior Member
thomaswomas has a reputation beyond reputethomaswomas has a reputation beyond reputethomaswomas has a reputation beyond reputethomaswomas has a reputation beyond reputethomaswomas has a reputation beyond reputethomaswomas has a reputation beyond reputethomaswomas has a reputation beyond reputethomaswomas has a reputation beyond reputethomaswomas has a reputation beyond reputethomaswomas has a reputation beyond reputethomaswomas has a reputation beyond repute
Using Aux Sends For Adding Effects
Hi,
my band have decided to record some new demos and want to do it all live. we've got an old studiomaster 20:8:2 desk which we've been using for the past year but we've never had it set up to record decent live demos yet. up to now, each instrument has it's own channel but i need to add some compression and reverb to things like the vocals and snare etc. i've hit a brick wall when trying to add effects though. i've got the main aux 1 send routed to the input of the reverb unit and the output of the reverb running back into the aux 1 return. when i increase the level of the aux 1 nob on any of the channels to maximum, i can barely hear the reverb and it sounds distorted. i've tried returning the reverb signal into a separate channel on the desk but it is still very faint. It works fine when i use the insert ports on each channel, but i need reverb on more than one instrument so i need to use the aux. can anyone tell me where i'm going wrong,
thanks
simon
Old 10-16-2006
Mark7's Avatar
Mark7 Mark7 is offline
Human 2.0
Mark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond repute
Is there an aux 1 return volume control?
Orbiting this at a distance of roughly ninety-two million miles is an utterly insignificant little blue green planet whose ape-descended life forms are so amazingly primitive that they still think digital recording is a pretty neat idea.
Old 10-16-2006
Junior Member
yes, i've got that turned up full. as far as i know, i've got all aux related nobs turned up full. i think a couple of photos of the desk layout would help so i'll get some done today
thanks
Old 10-16-2006
Mark7's Avatar
Human 2.0
Do you know if the aux return circuit is set up for +4 or -10 operation? And, in relation to this does your reverb operate at +4 or -10 or is it switchable?
And what's the phrase I should have used instead of
Old 10-16-2006
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
How heavily is the input reading on the reverb unit itself? Also, if it is reading good signal, as well as the output of the reverb unit, try returning the signal to a channel instead of an aux return
Dealer for Peluso Microphones, Blue Microphones and CBI cables....
http://www.myspace.com/xstaticstudios
Old 10-16-2006
gtrman_66's Avatar
gtrman_66 gtrman_66 is offline
Dedicated Member
gtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond repute
Also, check to see if there is a "wet/dry" control on your effects unit. Generally, you can run the unit 100% wet and control the amount with the aux send/return controls
good luck
Old 10-16-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Bring the reverb back into a set of channels via the line input.
Make sure the reverb unit is set to 100% wet.
The distortion iis from sending a bunch of tracks into the reverb at maximum, you are distorting the reverb unit.
If you still want to use the aux return, make sure that the return is routed to something that is turned up.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
More Aux tracks sends and returns walters Mixing / Mastering 20 08-20-2006 06:39
NUENDO aux sends ecktronic Cubase User Forum 5 07-10-2006 12:08
Mixer > Computer > Monitoring? I am all screwed up... scottboyher The Rack 13 04-09-2005 09:11
Using a compressor. Insert or use the aux sends? solarscar Mixing / Mastering 9 07-29-2004 11:12
