Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 10-14-2006
sirslurpee sirslurpee is offline
What does THIS button do?
sirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond repute
Sequencer to go with cubase
I didn't really know where to put this, so I posted it here. I am using a firepod that came with Cubase LE, I am looking for some sort of sequencing utility that will help me write simple drum parts, piano, violin, stuff like that, then import it to cubase. I've used fruity loops before but it's kind of difficult to use imo, but I will use it if I have to. I am just looking for alternatives.
Thanks.
Old 10-14-2006
fraserhutch's Avatar
fraserhutch fraserhutch is offline
Flypaper for freaks
fraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond repute
What's wrong with Cubase?
Thanks.
The fact that no one understands you doesn't mean you're an artist...
Old 10-14-2006
How do I just up and add a piano into cubase without actually hooking it up to the inputs and playing the piano?
Old 10-15-2006
electricabanana electricabanana is offline
Newbie
electricabanana will become famous soon enough
there is some way to make vst instruments in cubase i think...? but i always use propellerhead's reason. it goes into cubase as a rewire device (they sync together automatically and are designed to wiork together) and is pretty easy to use. if you havent used it before, its worth checking out (depending on what kind of sound you want).
Old 10-15-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
Cubase is a fantastic sequencer and VST was developed specifically for cubase and later adopted by everyone else. If you need to add a piano part and dont have a piano, find a free plugin at http://www.kvraudio.com/ that has what you need then read up on adding midi tracks
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 10-15-2006
L'espion Noir L'espion Noir is offline
Force of Nature
L'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond repute
as you know cubase has some vsts you should look into midi controllers this way you can use your professional sequence i.e. cubase
Old 10-15-2006
TelePaul's Avatar
TelePaul TelePaul is offline
J to the R O C
TelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond repute
add a VST instrument to a midi track...LEs stock instruments I'm not familiar with, and they wont be of the same kind as Reason (especially the drums) as Reason I think is developed more for Electronica and synth, or that wa smy understanding of things. The quality of the sound will depend on the quality of the midi sample
Originally Posted by Gummblefish
Went out yesterday all day long and spent 125 quid on a bender (not literally a bender )
Old 10-15-2006
Thanks guys.. I'll do some reading for sure... I didn't really know that's what VST was but I guess I'm an idiot and need to read more... Thanks again!
drum sequencing in cubase? mancalledaerodynamics Cubase User Forum 5 01-15-2003 04:27
Thoughts on Cubase SX for Non-Tecnophile rkellus Cubase User Forum 17 07-20-2002 11:46
Cost Analysis: Cubase SX versus Digi 01 with Pro Tools LE rkellus Digital Recording & Computers 9 07-04-2002 20:48
Cubase records mono only, neno Cubase User Forum 6 06-11-2002 01:56
CUBASE editing audio NYMorningstar Cubase User Forum 1 04-14-2002 01:51
