can't quite figure this one out...
Hey guys, I have a Boss GT-6, but I can't seem to figure it out. I want to use it to record direct, but when I go from my guitar---GT6--audio interface...my volume is WAY too low. I can have the patch volume all the way up, and have my gain on my interface (M-audio fastrack) cranked, but to no avail. Am I missing a step?
It's turtles all the way down... |
Isn't there a master output volume knob? There has to be another volume control that you didn't notice.
Yes
My music is here: http://www.soundclick.com/bands/pagemusic.cfm?bandID=274310 |
Could it also be that he is running a -10 output to a +4 input?
I did notice the master output, and it is cranked to the max.
What did you mean by a -10 to a +4?
If I add the effect to a recorded track I run my GT6 as an Aux Send and return from my board and don't have any problem. Usually if I know which sound I am going to use I will just send it through an amp and mic the amp. Typically that sounds better anyway.
There is a VERY good chance that your soundcard is set up to recieve a +4 signal. In reality, there is about a 12dB difference in those levels. Usually, you can change the soundcard reference level setting either via a switch, or via software. Since you didn't give complete info in your regular post, it is all speculative at this point! ![]() |
| What mic would you get with a figure 8 pattern? | Marcellovalerio | Microphones | 7 | 11-12-2004 14:08 |
| Figure 8 | capnreverb | Microphones | 9 | 09-21-2004 20:50 |
| cant figure out | alecmcmahon | Newbies | 1 | 07-18-2004 21:09 |
| Figure of Eight Question | longsoughtfor | Microphones | 5 | 04-29-2004 06:29 |
| have some equipment, but can't figure it out | breestillwater | Newbies | 3 | 12-30-2002 19:55 |
