Old 10-13-2006
tribal tribal is offline
Junior Member
tribal is on a distinguished road
Exclamation Do drums has to be always 1st?
Hi, I am doing multi track computer recording (Alesis multimix 16 f/w) and I usually start up recording with Acoustic guitar cos it's my 1st instrument. I usually record drums later cos I like break, slowed and filling on the drums. But it seems impossible to perfect the timing all the music together . I'm using Cubase Le version (will upgrade to SX or Sonar 4,5,6 sometimes later) at the moment, is there any drums loop or anything to fix my problems? or if you could pass me your technics I'd be much appreciate.
Thanks, V for Van
Old 10-13-2006
blueroommusic's Avatar
blueroommusic blueroommusic is offline
you want this big boy?
blueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond repute
I usually track drums first...since that holds down the RHYTHM. It's much easier to play off the drums, rather than the other way around IMO.
I come from the taint of America, so don't bitch at me about your f*#@ing problems. You don't have to wake up everyday smelling like a mix of ass AND balls.
Old 10-13-2006
Track Rat's Avatar
Total Gear Slut
It doesn't matter what you put down first. If you know how to play, you just play. If you have a hard time with timing, it's because you have a problem with timing. Only practice and talent will overcome it.
Mike
Old 10-13-2006
RAMI's Avatar
RAMI RAMI is online now
www.ramirami.com
RAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond repute
The answer is NO. Drums don't have to be first. But if you're tracking something else first, you should at least play to a click or simple drum beat. You can then lay your drum track later. Even though I'm a drummer first, I do my drum track last when I record. I play all my other tracks to a simple drum machine beat, and then do the drum track while listening to the rest of the "band" (which is me).
Old 10-13-2006
Junior Member
Do you guys use Metronome? I haven't try it out with it yet,do you think it would help my timing? I normally draw out bars cos I don't read or could write notes...
Old 10-13-2006
mikeh mikeh is offline
2.5K Gold Member
mikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond repute
As already stated, drums don't have to be first - instruments can be recorded in any order if they are played accurately and in time (which is why click tracks have become the norm). However, I do beleive it is easier to lay tracks if you have a solid rhythem section to follow.
I normally lay down a solid rhythem guitar track (played to a click track) - so there is a chord progression to follow (making it easier to know where in the song you are). I then lay down the drums, followed by the bass. This way I have a solid rhythem section to follow. Often I may delete the rhythem guitar once the drums and bass are tracked (often the song does not need a rhythem guitar track - so once it has served it's purpose of acting as a guide track it can be erased).
That all being said - given that my main ax is the drum kit, I do prefer to have the drums tracked first (preferably with either the bass or a rthythem guitar) - because trying to lay down a drum track after the other instruments are staggering all around the tempo can be a very hard challenge for even the best of drummers.
Old 10-13-2006
dirtythermos dirtythermos is offline
Dedicated Member
dirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond repute
If you get Sonar 6, you no longer have to play in time. You can fix it all in the mix. You can record the most off-rhythm mixed-tempo mess on your guitar and then sync the drums up perfectly!
As amazing as that is, you will be a much better musician if you practice with the metronome.
Third Take a blog about home recording
Old 10-13-2006
zacanger's Avatar
zacanger zacanger is offline
of Angry Man Records
zacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond repute
I used to do drums first, but now I'm recording on the computer more I usually have a click track and a guitar reference track, then I can do stuff in whatever order I want.
Old 10-13-2006
ez_willis's Avatar
ez_willis ez_willis is offline
Virtual Ninja
ez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond repute
I record a scratch guitar track to a metronome, then record the drum track and build from there.
Originally Posted by 60's guy View Post
You win.
Old 10-13-2006
omtayslick omtayslick is offline
1K Silver Member
omtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond repute
I lay down guitar first, using drum loops for timing. I find the loops easier to stay with than a click. Then add real drums later, and delete the loops.
Tom
Old 10-13-2006
gitRhero gitRhero is offline
3 chord wonders
gitRhero has a spectacular aura aboutgitRhero has a spectacular aura about
Same here, I have a real hard time playing to the click track in Cubase. Instead of loops I just load up a basic midi drum trk I made as a template.
Set the tempo and play. Do the real drums later (well real samples...lol), usualy built up from the basic midi drum trk.
Listen to my recordings
  #12
Old 10-14-2006
get2sammyb get2sammyb is offline
Dedicated Member
get2sammyb has a reputation beyond reputeget2sammyb has a reputation beyond reputeget2sammyb has a reputation beyond reputeget2sammyb has a reputation beyond reputeget2sammyb has a reputation beyond reputeget2sammyb has a reputation beyond reputeget2sammyb has a reputation beyond reputeget2sammyb has a reputation beyond reputeget2sammyb has a reputation beyond reputeget2sammyb has a reputation beyond reputeget2sammyb has a reputation beyond repute
I seriously recommend you play to a click or simple midi beat
  #13
Old 10-14-2006
rayc's Avatar
rayc rayc is offline
L'ancien escargot
rayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond repute
What RAMI et al said - if not drums & guide THEN CLICK goes the shears boy. Click, click, click.
Cheers
rayC
soundclick, unearthed, mspace & utub
  #14
Old 10-14-2006
Junior Member
I should definitely try out with click, click, click next time, thanks for the information guys.
V
  #15
Old 10-14-2006
up-fiddler's Avatar
up-fiddler up-fiddler is offline
Taming the World--for now
up-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond repute
Listen to RAMI. He knows of what he speaks and his timing is impeccable. Seriously, this is a good way to do it provided you don't have any ritards in the middle of the song etc.
Studio
Dave's Blog
  #16
Old 10-14-2006
Markaholic's Avatar
Markaholic Markaholic is offline
More Me In the Monitors!
Markaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond repute
I play all my other tracks to a simple drum machine beat, and then do the drum track while listening to the rest.
Thats what i do...lay a scratch track to a simple beat...once thats done...i go back and add all the fills and changes to the drums...then i go back and re-record some real takes.
  #17
Old 10-14-2006
grn's Avatar
grn grn is offline
www.michaelchagnon.com
grn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond repute
one thing you learn very quickly is to always fix it in the mix and rely on computers
Michael Chagnon
Twitter
MySpace
  #18
Old 10-14-2006
RAMI's Avatar
www.ramirami.com
Yeah, there's great advice.
  #19
Old 10-14-2006
TragikRemix's Avatar
TragikRemix TragikRemix is offline
I am NOT a Gear Whore. ;)
TragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond repute
ehhhhh.... tough situation, i know how it is being a lone musician and engineering it at the same time..
the answer- NO..... as long as you play with a click, and then you can keep up with it on drums.
if i am recording a band...
i like to first do a complete scratch track, where i make everyone play live and record that, adjust levels quick, and bounce the drums to a stereo, and leave everything else independent.
i like to then do drums first, as i find they take the most time.
other times, i choose to do the 'weakest' player first, anticipating muchos editing to get out of the way.
GFCG Member: 000 029
F**k Your Scene.
  #20
Old 10-15-2006
Junior Member
Thanks guys, hey, TragikRemix, your idea of record a band is interesting I'll try that, I love live performance music it's also getting to know someone who's really talented or good. I don't understand how someone could be so popular over the world and very bad at live performance. If you are good at live that's means you're really good
V for Van
  #21
Old 10-15-2006
DAS19 DAS19 is offline
Me, You, And Davey Too!
DAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond repute
Tribal I have Cubase LE and I just use their metronome built into the program it works find and youll find practicing to one gets you really good with timing. I usally do drums last I would like to do them first but I cant make up drum beats without someone playing the guitar and im a one man band.
  #22
Old 10-15-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
You can do that in any DAW, not just sonar.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
  #23
Old 10-15-2006
superbeatballer's Avatar
superbeatballer superbeatballer is offline
Force of Nature
superbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond repute
You could always make a scratch guitar track played to the metronome, record the drums, and then record your keeper guitars.
Originally Posted by superbeatballer View Post
Thanks for the cool new signature.
  #24
Old 10-16-2006
zacanger's Avatar
Erm, right. Sure.
  #25
Old 10-16-2006
Vadim Vadim is offline
Senior Member
Vadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond repute
No Metronome ?!?! I use metronome 99% of the time.
100% when MIDI sequencing, 100% when multi tracking, especially for the first tracks.
10% when recording piano solo, accordion solo or something semiliar...
tracking drums, what sort of room? drummersteve Recording Techniques 20 04-10-2006 16:01
all about sequenced/sampled drums n8tron Drums and Percussion 8 01-30-2006 20:47
mixing drums, gain, and compression question fl junkie Mixing / Mastering 2 11-03-2005 19:28
My drums sound boring gasal69 Roland, Boss, VS Series Forum 13 04-22-2005 10:53
