Inputs/Outputs in Converters
I'm looking at some converters such as the Apogee Rosetta....my question is that, why do the Rosetta, for example, have XLR inputs and outputs? Are those inputs or outputs necessary if I just connect the word clock out to my MOTU 828mkII's word clock in?
Those XLR inputs are for balanced cables, and are single -channel analog audio. There may be some that are AES/EBU which carry 2-channels of digital audio.
These are all different from the BNC wordclock cable. Wordclock does not carry any type of audio, it carries a sync stream. Quote:
The fact that no one understands you doesn't mean you're an artist... |
So how would i connect it to my motu? SPDIF? Is that all i need to connect the converter to my motu? a single SPDIF cable?
http://www.capitolflags.com/images/c...ebel-small.gif |
Do you really understand how this works? And why you are wanting to use it?
How many channels of conversion do you want out of the Rosetta?
Dealer for Peluso Microphones, Blue Microphones and CBI cables.... http://www.myspace.com/xstaticstudios |
Well, I'm just curious to know. I'm not buying it. Since I'm still new into recording, I want to learn more, piece by piece.
xstatic, i want the preamps and the analog ins to go through the converter. |
How I use my outboard AD convertors: 8 analog ins each (balanced XLR) and I take the ADAT out (8-channels lightpipe) and run that to my digital board. I have 16 channels of outboard AD I use this way. One of the units has DA (digital->analog) so I use the ADAT out from my board into that unit. So, to recap, all analog ins are balanced XLR. Adata is lightpipe. I don't use the AES/EBU connections. All these units do is convert from anaolog to digital and vice-versa.
Who ever gave me that neg rep regarding the Apogee, I said that I'm not buying an Apogee. I just referred to it for an example cause I was eager to know. If you're gonna stop me from learning, then fuck off.
| whats the difference between a analog tape deck converters Vs DAC and ADC converters? | walters | Analog Only | 27 | 09-06-2006 14:46 |
| RME fireface converters vs. Mytek converters | BRIEFCASEMANX | The Rack | 14 | 07-06-2005 22:36 |
| Layla vS delta 1010 converters? | jeff0633 | Digital Recording & Computers | 3 | 06-29-2005 17:57 |
| built in a/d converters | dr.colossus | The Rack | 3 | 11-30-2004 15:44 |
| A dumb question about A/D converters | geekgurl | The Rack | 6 | 02-28-2002 14:13 |
