Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 10-11-2006
Rokket's Avatar
Rokket Rokket is offline
Sgt Floyd Pepper
Rokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond repute
Stupid input jack...
... on my bass is acting up. I plug in my patch chord and have to wiggle it around to make contact and be able to play. The result is a horrendous noise (snap, crackle, pop...) when I do this, and it usually happens when I don't want it to (like during church when the pastor is praying ). Sometimes I can just plug in and play without messing with it, but most of the time, I have to wiggle the damn patch chord. Beyond replacement, how can I fix the jack to stop this from happening? Re-solder? Bend the contact points?
The hardest part of being a bartender is figuring out who is drunk, and who is just plain stupid.
Old 10-11-2006
Rokket's Avatar
Sgt Floyd Pepper
I should add too that I have active pickups, in case that has any bearing on it...
Old 10-11-2006
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
Why is it "beyond replacement?" Soldering in a new jack seems like the easiest, most reliable, fix.
"That was so terrible, I think you gave me cancer!"
My tunage
Old 10-11-2006
Rokket's Avatar
Sgt Floyd Pepper
I just didn't want to go through the trouble... I was hoping there would be a fix that didn't involve soldering in a new jack.
Old 10-11-2006
Jouni Jouni is offline
1K Silver Member
Jouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond repute
..or bending the contacts, if you're sure it's not the cord..
\m/ WAR OUT!! \m/
Old 10-11-2006
Rokket's Avatar
Sgt Floyd Pepper
It's not the cable. I've had the same problem no matter which cable I plugged in. I guess I am going to go get a new jack and solder it in. No sense causing further problems by accidentally breaking off a contact.
Thanks anyway!
Old 10-11-2006
cephus's Avatar
cephus cephus is offline
Slow Children Playing
cephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond repute
the bending the tip contact will probably help because it will serve to wedge the jack in there against the sides where the sleeve touches. If the nut was loose and you managed to spin the whole socket around, you could have boogered up the soldering, but it is more likely that the jack is just sloppy in the hole. When you take the jack out to bend it, you can check the solder. If the wires are only still attached by a few strands, then you should skin the wires and resolder them. You can't really mess up soldering a jack too bad. If you don't knwo how to solder, a jack is a good place to learn. If you try and learn on a potentiometer, you could cook it. If you go to radio shack, get the thinnest solder they have. I don't know how many times I've seen someone with that plumbing solder out in the garage. I don't even know what it's made of, I just get the thinnest kind so it melts quickly.
Boo
Do not read this.
Old 10-11-2006
Rokket's Avatar
Sgt Floyd Pepper
I already looked at the wiring, and it's still solid, so I suspect you hit it on the head with the sloppy contact. I just don't want to bend it too much, or chance breaking it.
I have a guy who is pretty good at soldering who will do it for me. He knows better than to use plumbing solder on a guitar, I would hope. He works on electronic stuff for a living.
Thanks!
Old 10-11-2006
gcapel's Avatar
gcapel gcapel is offline
boom box recordings
gcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond repute
get a 2-3 dollar switchcraft jack and replace the thing. It takes a few min. Wire the signal to the tip and ground to the sleeve.
Old 10-11-2006
TelePaul's Avatar
TelePaul TelePaul is offline
J to the R O C
TelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond repute
Input Jack? On your bass? Do you mean OUTput jack? Or the 1/4 inch cable your running out of your bass?
Originally Posted by Gummblefish
Went out yesterday all day long and spent 125 quid on a bender (not literally a bender )
Old 10-11-2006
Rokket's Avatar
Sgt Floyd Pepper
I am going to go look for one tonight, thanks!
  #12
Old 10-11-2006
Rokket's Avatar
Sgt Floyd Pepper
By the way, what difference is there between a jack at Radio Shack and buying, say, a Fender or other jack at a music store?
  #13
Old 10-11-2006
ggunn ggunn is online now
Crystal Flavolian
ggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond repute
More than likely all that is needed is to take the jack out and bend the metal piece that captures the tip of the 1/4 inch plug more into the path of the plug so that it grips more snugly. Replacing the jack is necessary only if something breaks off of it or if the components of the jack get loose. Don't make this harder than it neeeds to be; replacing the jack is most likely not necessary.
Gordon in Austin
http://www.crystalflavola.com
  #14
Old 10-11-2006
TelePaul's Avatar
J to the R O C
so it IS the output jack.
  #15
Old 10-11-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
If you have active pickups, you will need to buy a stereo jack. Most of the ones at Rat Shack are junk. If you don't know the difference, just go to a guitar shop. in fact, the guitar stor might have someone who can replace it for you while you wait. If it takes 10 minutes, I would be suprised. If it costs $15, I would be suprised.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
  #16
Old 10-11-2006
gcapel's Avatar
boom box recordings
looks like you have two options. Replace it and know that it is right or try bending the tip contact and count on fixing it again later.
Here's where i buy things like this for cheap. This guy buys large quanities and sells cheaper than large distributors like digikey or mouser and most def radio shack. If you have a paypal account you can order and pay online. I keep these jacks on hand cause there so cheap. Switchcraft is the way to go though.
http://www.smallbearelec.com/Categor...s+and+Fittings
  #17
Old 10-11-2006
travelin travis travelin travis is offline
Banned
travelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond repute
rokket, just bend it man. it takes a about a whole minute to do. if it's still acting up after that, you have a bad solder joint. solder joints can look fine and still give you some problems. one of the best tools i ever bought was a decent soldering iron. i could'nt live without it. also, don't buy any of that lead free crap solder. 63/37 kester is good stuff. a decent soldering iron and good solder can save you alot of headaches and money.
i remember being charged $30 to have a input jack fixed (resoldered) on my amp when i was a kid.
  #18
Old 10-11-2006
RandyW RandyW is offline
Force of Nature
RandyW has a reputation beyond reputeRandyW has a reputation beyond reputeRandyW has a reputation beyond reputeRandyW has a reputation beyond reputeRandyW has a reputation beyond reputeRandyW has a reputation beyond reputeRandyW has a reputation beyond reputeRandyW has a reputation beyond reputeRandyW has a reputation beyond reputeRandyW has a reputation beyond reputeRandyW has a reputation beyond repute
I would go with bending the jack first, I would also recommend cleaning it with some deoxit and then lubing it with progold. I have recommended them so much you would think I worked for them. While you got it pulled out you migth want to check the solder joint. It would hurt to clean the cables as well.
With active electronics I suppose it could possibly be a dying battery causing the popping sound. Have you replaced the battery lately?
  #19
Old 10-11-2006
cephus's Avatar
I know they used to be junk. The radio shack nearest me closed up and during their last days of business they had this huge table of the hanging bags, mix and match 10 for a dollar. I bought 10 bucks worth of knobs and piezo buzzers and roach clips and stereo output jacks. These jacks seemed identical to the switchcraft or Fender ones I had in my pieces parts drawer.
I prefer mechanical means of cleaning those jacks. I have a wire bottle-brush looking thing I bought from harbor freight. It will scratch up the sleeve part of the connector nicely. I think it's for cleaning guns.
Boo
Do not read this.
  #20
Old 10-11-2006
Banned
One of the local ratshacks here closed down recently and I bought a bunch of connectors, jacks, switches, clips, etc. for pennies on the dollar. Some of the stuff is decent quality. I have'nt had a chance to use any of the jacks yet so I can't say how good/bad they are.
  #21
Old 10-11-2006
Farview's Avatar
I know they used to be junk. These jacks seemed identical to the switchcraft or Fender ones I had in my pieces parts drawer.
That's why I said most. They carry both the good and the bad, that's why I told him if he didn't know the difference, go to the guitar shop.
There are alos a few different kinds on guitar jacks, a guitar shop should have all of them.
Jay Walsh
  #22
Old 10-11-2006
Light's Avatar
Light Light is offline
Born in the Light ofStars
Location: Creating saw dust at rapidly increasing levels
Light has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond repute
Bending the contacts back in (or "retensioning" as the vintage amp guys call it) can help for a while, but it really is mostly a temporary fix. It is also impossible with enclosed jacks. More to the point, with many of the cheap jacks used in most production instruments, it is as likely to snap the contact as to "retension" it. Personally, I think it is usually better to replace it with a good quality switchcraft jack. If your bass is active, you will need a stereo jack (unless it is stereo and active, in which case you need a 9 pin jack, which may be hard to find).
Most jacks are really cheap, though, so there is not much reason not to replace them.
Light
"Cowards can never be moral."
M.K. Gandhi
  #23
Old 10-11-2006
Crystal Flavolian
FWIW, I retensioned the output jack on my '61 Strat in about 1988 or so, and the repair is still holding. Temporary it may be, but 21 years (and counting) is pretty good for a temp fix.
One tip for doing this is to hold the metal clip a little ways out from the jack with a pair of needlenosed pliers and do your bending out past that point instead of bending it more right there at the jack where it's already bent 90 degrees. Less metal fatigue.
Gordon in Austin
  #24
Old 10-11-2006
Banned
i've re-bent a few jacks myself and never had a problem. it does'nt take much, just a couple of degrees is plenty. if someone breaks a jack by re-bending it, i would guess that
a) the jack was about to break anyway
b) that person is completely incompetent
  #25
Old 10-11-2006
Rokket's Avatar
Sgt Floyd Pepper
Thanks for all the input (no pun intended!). I am going to open her up tonight and see what happens...
Input speaker connections (jack) Dangermouse Other Equipment and Reviews 3 06-14-2005 08:08
Cubase 2, Delta 1010LT, input levels very low ticker Cubase User Forum 0 06-09-2004 15:04
Specs VS840 Ex BrettB Roland, Boss, VS Series Forum 9 01-14-2002 16:12
Converting MIDI to WAV AndrewSales Cakewalk / Sonar Forum 38 08-21-2001 22:31
ART Tube MP Input Level Raj Microphones 12 02-28-2000 09:16
