Strat pickup wiring
I'm replacing the stock clean meek "weak" stock pickup in a HW!.
I have a SCN neck pickup I would like to use with a mid and bridge Texas special combo. I figured this should give me an extra clean position along with the other two. I slapped the new pickups in without any other changes such as caps etc. Everything sounds good except for position 2 the front and mid combo it sounds like a lose in volume "possibly out of phase" and very tele twangish. I would be bad except for the lose of volumes it makes it sound like a complete different guitar. I checked the wiring for SRV strats and it looks like all they use is a .022k cap on one of the tone controls. I'm wondering if I can get by with that or if I will need something different for the SCN. Anyone tryed mixing these pickups. The std wiring for a HWi has a couple smaller caps and film resisters in the circuit. I'm comptemplating just getting rid of the excess components and putting in a .022k cap unless someone has a better ideal. |
Try switching the black and white wires on the unusual pickup (i.e., the SCN). See if that fixes it. If it is a polarity problem, that will do it. As far as the caps, the single cap in most strats is used for both tone controls. I very much doubt that the problem is in the controls though. Most likely, the SCN is just wired backwards from the Texas Specials.
Light "Cowards can never be moral." M.K. Gandhi |
SD.com
if lights suggestion does not work (and since strats come wired rev-phase and rev-polarity in the middle, I do not think that is the problem) head over the www.seymour-duncan.com and hit their forums. Most info and help related to wiring available on the net.
The middle pickup on SOME strats is reverse wound/reverse polarity. But that has nothing to do with how you wire it, unless of course you put a middle pickup in a neck or bridge possition. If THAT is the case, they you need a new pickup, becuase no matter how you wire it it will either buzz or it will be out-of-phase. Light "Cowards can never be moral." |
| Mix My Song!!! | RAMI | MP3 Mixing Clinic | 461 | 08-11-2006 08:43 |
| Adjusting pickup height (Tutorial) | enferno | Guitars and Basses | 0 | 02-06-2005 23:48 |
| A quick, simple Tele' pickup wiring question | Easto | Guitars and Basses | 3 | 09-20-2004 09:30 |
| USA Strat Pickup Suggestions? | mike2731 | Guitars and Basses | 9 | 02-20-2004 12:18 |
| strat wiring help | cordura21 | Guitars and Basses | 4 | 05-13-2002 07:59 |
