decent affordable pre amp?
Hi there, i am after a decent cheap pre amp, maybe something with a valve, i want to get a warmer signal, can anyone reccomend anything, i am currently using a behringer ada8000, which is not bad but i am looking for a preamp that give off a more distinctive sound.
Can anyone give me a few names of some decent 2nd hand stuff? I was also looking at a TUBE ULTRAGAIN T1953or a ART Tube MP Studio V3, i was planning to swap the tubes around with some better ones in each, i heard can make a big improvement. Anyone got any ideas, i have about 200 maximum to spend or 100 each for 2 channels of preamp thanks matt |
First, don't double-post. Second, for a super-affordable tube preamp that sounds pretty good, check out PreSonus, they make some decent stuff.
I'd stay away from the Behringer pre's - they aren't bad, but aren't really "tube" preamps. They are solid state and then pass the signal through a preamp tube on the way out of the signal chain. You'd think this would make an audible difference in the sound of the pre, but on the one I own, if you have a signal running through (a voice through a condensor, etc.), and you turn the "warmth" knob back and forth from 0 to max, you can't really hear a difference. Like the guy above said, PreSonus has some decent stuff. If you can, scrape together another hundred and go for the Art MPA Gold, it has a very transparent sound and is much higher quality, IMO, than any Behringer preamp.
I would recommend the M-Audio DMP-3. Only about 160 bucks, really clean and gets pretty nice reviews across the board.
Some of my music |
Stay away from the cheap presonus stuff. I don't know who told you it was pretty good but I've owned presonus stuff from the tubepre up to the Eureka and none of it was a big improvement over my ada8000. SP vtb-1 is a decent toob pre amp, dmp3 is a stellar(for the pricerange)clean preamp, and if you really want "color" you should check out the joe meek 3q which has a handy compressor/eq built in. Trust me I've owned or own all the pre's I mentioned so it's not just based on the belief of others. Last edited by jonnyc; 10-17-2006 at 13:32.. |
You're not gonna get any decent sounding tube pre's at that price range.
thedogmixer: the Art MPA Gold isn't a bad pre (but a little out of range price wise). What are you planning to record? Vocals, guitar, bass? Everything? I think you'll find that the Behringer offerings are bit too noisy, and you would certainly be better off with an ART of some sort. How about mics? What do you have available? |
G. |
I am selling an ART Digital MPA for a little over 200 and in essentially perfect shape.
Below is a link to my online ad in local listings. PM me if you are interested. http://sandiego.backpage.com/musicia...%2Finstruments |
#12
You can do better for the $$$ in that range anyway. |
#13
| Guitar Cab Impulse Files | Keiffer | Guitars and Basses | 30 | 02-19-2008 19:41 |
| Pre Amp | Jimmy2002 | Digital Recording & Computers | 5 | 04-11-2005 08:18 |
| Looking for a decent amp modeler | skunizzi | Guitars and Basses | 15 | 07-25-2004 02:40 |
| Running keyboard into pre amp? | K9SaVeLLi | Recording Techniques | 3 | 01-24-2004 19:52 |
| Studio Projects pre amp into SB Live... | FromVa2Ga | Newbies | 3 | 12-03-2003 18:19 |
