Does the Compressor plug in work?
Hey guys, i am using cubase le. I can't seem to stop those peaks! i use the compression under "dynamics" in the program, but really no mattewr which i turn the knobs, nothing too drastic happens. I have it as an insert effect, its on, but i dont know what to do. I started working with a metal band, (new wave of british heavy metal, and i am really pushing the kick and snare. Luckily, I just recorded drums to have have them dump it into logic later on.
I want to get this down right becuase peaks are always a problem for me. I can never get anything loud enough without being over. I might have to get some other compressors, but for the eman time, does anyone know what the hell i should do? Thanks in advance! Flame
Presonus Firepod (x2) Presonus Faderport Cubase Studio 4 Sennheiser E604 (x4) AKG D112 Sm57 Sennheiser e906 AKG Perception 200 Mesa Boogie Duel Rectifier Peavey 5150 Yamaha Stage Custom Yamaha HS80 Monitors Yamaha Subkick |
The Cubase dynamics plug just doesn't sound very good, imo.
Here are a couple of freebies to try: Blockfish Classic Compressor and Classic Master Limiter W1 Limiter If you are just wanting to get things "louder," the limiters will help you more than the compressors. Read more about compression, here. |
You really shouldn't be concerned with "sheer volume" at the mixing stage anyway... If you're peaking, you're probably mixing too hot. That's pretty much all there is to it. Certainly if you're trying to mix to "acceptable commercial levels" (then you're probably mixing WAY too hot).
But the dynamics in Cubase should still work - Are they providing *any* gain reduction? |
I have a question...whenever I'm mixing vocal tracks with instruments in Cubase, the clipping indicator appears. Even though the sound is not distorted while playback, will this affect the overall export quality of the song when I render it to a mp3 file? Cause I find the song quite rough when I hear it in Winamp.
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F. |
http://www.floridadiy.com |
Thanks guys. I guess i am mixing way too hot. I pump up the level during mastering? And i actually had a good thread about how loud a person should record using a digital system, any ideas? i remeber hearing max it at 18dbs, but that seemed very low on the VU. Any suggestions
yea thats about right for tracking. by the time i'm done mixing it ends up sounding quite a bit louder than that. make the rest up when you're done mixing. hell you can even slap a limiter as an insert on the stereo out if you want to do quick "loud" mixdowns for friends....
Also, to avoid to getting the masters to clip, would it be useful to put instruments to different buses? For example, i have all of my drums going into a "group" track titled "drums". Now this is going into Bus 1. Should i put to bus 2, and record all my guitars on Bus 1, and vocals on Bus 3? Would it work in the final mixdown or is this not necessary for what i am doing? I record metal bands, and they want it all loud! Would the buses help me?
#12
#13
Cool, that works. I tried recording and mixing lower, drums and bass. It came out ok. I wound up throwing it into t-racks to pump up the level a bit. Finally, Clipping is not the main problem and ceiling to my mixes! THANKS GUYS! AS far as mixing go, i use the faders i recorded on, then dump the guitars in "guitars" group, so on, this way i have total control.
| Songs and Death | Jack Russell | Songwriting, Singing & Vocals | 26 | 10-05-2006 12:56 |
| Why do some CD-R's not work in some players | ap | Digital Recording & Computers | 2 | 05-03-2002 07:51 |
