Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 10-06-2006
Obstacle1's Avatar
Obstacle1 Obstacle1 is offline
Incompetent at times...
Obstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond repute
EFX Loop inputs on my amp...?
Hey there, I have a Peavey Bandit 112 and have noticed it has EFX Loop sends (in&out) - can these be used with my effects pedals and if so how would I rig this? Also, what benefit does this give, if any?
Thanks,
Obstacle1
Fender Telecaster
Tanglewood Heritage TW1000B
Peavey Bandit 110
Boss ME-50, Small Clone, Boss DD-3
SM57, AT3035, AKGC2000b
Peavey PV8
Behringer Composer MDX2100, Behringer Virtualizer
M-Audio Audiophile 2496
Cubase SX2
Reason 3.0
Edirol MA-7A's
Old 10-06-2006
ez_willis's Avatar
ez_willis ez_willis is offline
Virtual Ninja
ez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond repute
EFX Send to pedal(s), out of pedal(s) to EFX Return.
I think they're inserted after the preamp, not before, like if you went from your guitar to the pedals, to the amp.
Benefit? Different(sort of?) sound.
I could be totally wrong though.
Old 10-06-2006
Anfontan's Avatar
Anfontan Anfontan is offline
Banned by eurt
Anfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond repute
Thanks,
Obstacle1
Preamp out to the input of the pedal-output of the pedal to the power amp in of the effects loop. You really just want to use pedals like delay, chorus, or phase shifter in the loop-distortion will not sound too good thru it-though to each their own I guess.
It will cut back on some of the overloading that running an effect through the front end of the amp can cause-as in through the preamp and then the power amp. In other words, the noise added to the effect is cut down and the actual effect is more pronounced!
Old 10-10-2006
VSpaceBoy's Avatar
VSpaceBoy VSpaceBoy is offline
..loading
VSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond repute
To add..
depending on the type (insert or parallel) you can run your effects along side of the original signal. Meaning you'll hear the raw amp tone, along with the pedals "tone" (effects).
For me? I've never found a loop I like. They always change my main tone somehow. Too loud, floppy bass, whatever. You can test it by running a cord from send right back into receive.
Old 10-10-2006
ggunn ggunn is offline
Crystal Flavolian
ggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond repute
Thanks,
Obstacle1
Generally, effects boxes (stomp boxes) work better in front of the amp than in the effects loop. Mainly that's because they are usually designed to work with instrument/mic level signal, and the signal in the effects loop is line level (hotter). There's also the underfoot cables to contend with; instead of one cable going to the amp, there would be three.
Effects loops generally work better for rack mounted units that are designed for line level I/O and that stay back with your amp.
Gordon in Austin
http://www.crystalflavola.com
Old 10-11-2006
Dani Pace's Avatar
Dani Pace Dani Pace is offline
Why 2K?
Dani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond repute
The hook up has already been explained. I just wanted to add, some digital efx seem to work a little better or quieter through the loop. Analog pedals work best between the guitar and amp. Distortion tends to get "grainy" sounding through the loop. Try your efx both ways and use whichever sounds better to you. There is no set rule when it comes to getting a certain sound, do whatever works.
The more I learn, the more I realize how much I don't know. http://www.soundclick.com/sixfeetover
weird effect blew up my amp?? baniak The Rack 17 05-30-2008 15:09
Guitar Cab Impulse Files Keiffer Guitars and Basses 30 02-19-2008 19:41
Multi effects processor advice for tube amp metalj Guitars and Basses 16 06-14-2005 13:26
facts about speaker power ratings gusfinley Guitars and Basses 18 01-07-2005 15:49
Lexicon 284 Class A Recording Tube Amp Pearldiver Free Ads for Music / Recording Equipment 2 08-02-2002 19:30
