Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 10-05-2006
TelePaul's Avatar
TelePaul TelePaul is offline
J to the R O C
TelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond repute
action
hey anybody know off hand a general string clearance for an acoustic? How does 2 mm at the 12th fret sound?
Originally Posted by Gummblefish
Went out yesterday all day long and spent 125 quid on a bender (not literally a bender )
Old 10-05-2006
muttley600's Avatar
muttley600 muttley600 is online now
The Central Scrutinizer
muttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond repute
Depends on string length, String gauge, neck relief.
What guitar? What strings? 2mm at the 12 fret is OK but on the low side. Where are you measuring the action, high E Low E?
Old 10-06-2006
TelePaul's Avatar
J to the R O C
Martin D 15, 12 guage thomastiks, low E at 12th fret. Thanks for this man.
Old 10-06-2006
Dani Pace's Avatar
Dani Pace Dani Pace is offline
Why 2K?
Dani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond repute
If it dosen't buzz, 2 mm at the 12th is good, better than most in fact. Around 4 mm at the 12th is probably clocer to average on acoustic, I consider 2 mm good on electric.
The more I learn, the more I realize how much I don't know. http://www.soundclick.com/sixfeetover
Old 10-06-2006
TelePaul's Avatar
J to the R O C
Im measuring from the actual fret to the underside of string...thats correct yes?
Old 10-06-2006
Dani Pace's Avatar
Why 2K?
Yes, we are discussing the actual space between the string and the fret.
Old 10-06-2006
TelePaul's Avatar
J to the R O C
great im pretty please so...is there a trick where you fret the first and 12th, go to the 6th fret and try pass a lectrum under the low E?
Old 10-06-2006
Dani Pace's Avatar
Why 2K?
I check neck relief by pressing a string (low E is easiest) at the 1st and about 15th fret, then check the space between the string and fret around the 7th fret. I look for about enough space to pass a medium pic between the string and fret. If the frets are good this is usualy enough to eliminate the buzz or fret rattle.
Old 10-06-2006
Light's Avatar
Light Light is offline
Born in the Light ofStars
Location: Creating saw dust at rapidly increasing levels
Light has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond repute
Spec action for a Taylor is 2/32 on the treble side, and 3/32 on the bass side. That would be about as low as you can go and still have your guitar be playable. Martin spec is a little higher at about 2.5/32 and 3.5/32. That would be about the middle of the road, and where I think most people should start out. It gives you a reasonably easy feel, but also gives you enough of a dynamic range without buzzing that you can make real music. Martin spec USED to be 3/32 on the treble and 4/32 on the bass. That is high normal. If you play loud and hard all the time (if you play bluegrass, for example), then that is where you will probably need to end up.
I'm not real good at metric conversions, but 2mm seems really low, if I remember right.
Oh, and measure all of these from the top of the twelfth fret to the bottom of the string.
Light
"Cowards can never be moral."
M.K. Gandhi
Old 10-06-2006
muttley600's Avatar
With a string gauge of 12's your gonna need a real good neck setup if you want to dig in and not get choking or buzzing. Lights specs for Taylor and Martin are about what I understood them to be. A rough conversion would be
Taylor 2/32" = 3.1mm
Martin 5/64 = 4.2mm
A good compromise between playability and sound for 12's would be somewhere in between. If 2mm works for you tho stick with it if it plays as you want.
I set up my acoustics with 12 -53's and aim for 3.5mm and 5.5mm. As you go down the gauges to 10's or 11's you need a higher action and you lose a lot of punch from your tone as well.
Neck relief needs to be what it needs to be and I don't measure it anymore but set it for the strings the customer asks for.
Old 10-07-2006
TelePaul's Avatar
J to the R O C
well thanks alot for that guys youve been really helpful
Low action: pros and cons killthepixelnow Guitars and Basses 36 06-07-2006 16:49
