Midi drums
Roland td3
Eurorack 802 Sonar 5 Soundblaster Live via game port lead. I'm good with sonar recording wave files but being new to midi it seems such a task. Been reading up all day and have the cables into my kit but seem lost now. Just some beginners tips would be welcome. Thanks |
what are u trying to accomplish?
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual |
hit arm on the midi track.
and then record. then learn about quantize. then learn about using the pencil and eraser to correct yourself.
GFCG Member: 000 029 F**k Your Scene. |
I'm trying to just record my drums to midi as i said
wave is no problem but i realise midi is better for these drums. hit arm on the midi track. and then record I plugged my cable into the drums onto my pc brought out a midi track on sonar tried pressing record but nothing seemed to record, i'll try again over the weekend, maybe some settings in my card need changed. |
M-AUDIO Audiophile 2496 decided on this after some reading.
thanks |
Got my card installed and it sounds awsome, one question as per norm,
in sonar should the midi outputs and inputs have the same driver, mine is showing Delta AP midi in both in and out. |
Can a USB connection work for midi? I have a Korg Pad Kontrol, and I'm using DFHS, and Sonar 5.
Yes, yes, yes.
The data that is sent thru a USB cable conforms to the Musical Instrument Digital Interface protocol standardized in 1983. It's pure, 100% MIDI. Nothing less and nothing more... .
...now in HD. |
the input should be Delta AP, and the output should be whatever you want to use to assign samples to the drums. whether that is Drumkit From Hell, BFD, DR-008, Battery, or any of the other slew of drum plugins available out there.
http://www.ryosa.com - subscribe to my twitter feed to immediately see when I release new stuff. |
| Midi drums, midi keys, Sonar 2 problem | Cartwright | MIDI Mania | 3 | 06-02-2005 09:04 |
| Reason and electronic drums and midi | Vullkunnraven | MIDI Mania | 3 | 04-15-2005 13:36 |
| FL Studio as a MIDI sequencer? | HairWuzEre | Keyboards and Sound Modules | 1 | 10-21-2004 12:37 |
| Need serious midi help whats the best way to do this? | puppethead | MIDI Mania | 3 | 10-09-2003 15:59 |
| Need serious midi help whats the best way to do this? | puppethead | MIDI Mania | 0 | 10-08-2003 22:00 |
