nylon d string breaks
something i've noticed over the years
with three different guitars a 40 year old flamenco from spain a 30 year old aria flamenco from japan an "old" crap classical from mexico it's always the d string that breaks i go to play and the guitar is sitting there with a d string broken between the nut and the tuner i don't think all three guitars have a tight nut "d" groove (and i've widened them) or that my house has a "d" gremlin (i've moved several times) is this a common problem like d's are at the limit of their tension when tuned or is it just me?
On all my classical guitars the D string is always the most likely to break. Also the one that loses brightness the fastest - so needs replacing the most often. Shouldn't break very often if you change it when it gets dull in tone.
IME they most commonly break at the saddle. If they're breaking at the nut use a little graphite in the slot. Tim |
thanks - i'll try the graphite
i'm tired of tying the string together and having it break again ![]()
In a period of about 5 years, the D string on my Alvarez nylon, acoustic-electric has broken 3 or 4 times at the saddle. No other stings have broken and none of my other (steel string) guitars have ever done that. This is very strange. Would like to hear more about this.
rpe |
Saddles that are relatively high in relation to the tie block of the bridge put lots of pressure on the string at the point of saddle contact.
You can minimize breakage by making sure that the top edges of the saddle aren't sharp, as it'll cut the string eventually. Tim Last edited by XLR; 10-05-2006 at 09:14.. |
Even stranger, my nylon string hangs on the wall and the D string on it mysteriously breaks at about the 14th fret while its just hanging there. I'll go in one day and see that its broken. Only the D string, and only on that guitar (3 other guitars hanging right alongside it).
I play electric guitar in that same room, and there are some serious standing waves when I play loud. I can only assume that the string drones sypmpathetically with the vibrations caused by my amp in my acoustically imbalanced room, and as the string weakens it just finally goes. Also on this guitar, when left alone, some strings tend to go sharp instead of flat like most guitars. Go figure. That thing has a mind of its own apparently. But its always the D string for me too.
________________________________________________________________ Everyone's a voyeur, they're watching me watch them watch me right now |
When you buy strings, buy one or two extra D strings for each full set you get. I buy bunches of them. Strings by Mail has a good assortment of individual high quality nylon strings. Change the D string after every 10 hours or so of playing, the other bass strings after 40 hours playing, the treble strings just when they get rough or the intonation becomes false. Your guitar will sound better balanced, brightness-wise, and you'll almost never have a D string break.
Tim |
(Oh, crap. I just noticed that when I restrung my electric, I hooked the G string under the B brace!)
Tim |
it's between the nut and the tuner like the nut is grabbing the string an putting more tension behind it but there's no popping sound as it is tuned nor any gradual drift to the pitch after tuning and now that i think of it they've occasionally broken in other places too - mid string and at the saddle but it's three different guitars and only the d i can't ever remember another string breaking classical guitars are just badly engineered, i guess ![]()
#12
cannabis, how often do you change your strings?
Tim |
#13
On a nylon string guitar, the D string has the smallest core. Particularly with nylon strings, where the core is not a solid core, but a bunch of nylon strands spun together and then wraped over, the smallest core string is always going to break the most. Most acoustic players break more G strings, and most electric players break more D strings. The windings do not add to the strength of the string (at least, not much), just the mass. It is the size of the core which determines the strings strength.
Light "Cowards can never be moral." M.K. Gandhi |
#14
and i guess the reason they don't make the core larger (and the winding gauge lighter) is that it would unacceptably change the tonal charactersitics of the string in relation to the others? Quote:
when the d string breaks? ![]() i really don't change them often enough but this last d went after only a week or so on the guitar
#15
thanks for the strings by mail info http://www.stringsbymail.com/ i got their pack of bulk martin 120's ($95 for 48 sets) http://www.stringsbymail.com/sublist...ssical+Strings and that should be enough to last me the rest of my life even stealing some extra d's from them ![]()
#16
you're obviously playing that string too much. pay more attention to the A and G.
Slim's Site |
#17
Admittedly unrelated, but have you ever had to have a neck reset or re-plane on any of those guitars? I have a la Patrie presentation (with a truss rod), and I was wondering if older classicals without this reinforcement will eventually need attention? Cheers.
#18
Refrets can be done (not often needed, as Nylon strings are a lot softer than steel, but they can still wear), but a neck reset is impossible on the Spanish and Mexican guitars, and possibly on the Aria as well. The Spanish and Mexican guitars are all but certainly made with a Spanish Heal, in which the neck block and the neck are one piece of wood, and the sides are let in to the block. Frank Ford has removed the neck from ONE guitar with a Spanish heal, converting it to a bolt on neck, but it is not something which is at all advisable, even if the guitar needs a neck reset. Nylon strings, with their much lower tension, rarely need neck resets, however. The Guitar Frank did, and all the Spanish heals I've seen in need of neck resets (and I've seen an awful lot recently) were all just poorly designed steel strings (poorly designed because the builders didn't have enough experience with steel string repair to realize that a removeable neck joint is not only a good design, but an absolute requirement on a guitar with steel strings). Most of the ones I've seen have been old B.C. Rich Acoustics from the seventies. Light "Cowards can never be moral." M.K. Gandhi |
#19
on a spanish heel ala frank ford (his link included) http://homerecording.com/bbs/showthread.php?t=206779
#20
I'm well familiar with it (if you had read my whole post, you would have known that), but even Frank doesn't do them very often (as in, not if he can talk the customer out of it), and he charges upwards of $1500 for it. Light "Cowards can never be moral." M.K. Gandhi |
#21
a little ingenuity may not be pristine but it is functional and a hell of a lot better than an unplayable guitar
#22
You know what? Frank is a good friend of mine. I've spoken to him at length about that repair. He's done it once. Did it work? Yes, it did. Was the repair more expensive than the value of the guitar? By at least three times. That is not a viable repair in my book. Light "Cowards can never be moral." M.K. Gandhi |
#23
a pissing contest with you here (i know where you're coming from - "don't try it yourself - leave it to professionals") but if a person can do the repair himself (which many here are certainly capable of - it's elementary woodworking, not brain surgery) then it's very viable and can resurrect a dead guitar if the guitar is worth more to the owner hanging on the wall then leave it alone if it's worth more as a playable instrument then fix it
#24
It is FAR from being elementary woodworking. It is an extremly demanding and precise job. It may not be brain surgery, but it would be very difficult for anybody who is not highly experienced with guitar work. There are quite a few aspects of it which require a great deal of experience with the precise geometry of a guitar. Even for the experienced, it is a job not to be taken without a great deal of planning and thought. Light "Cowards can never be moral." M.K. Gandhi |
#25
you go your way and i'll go mine
| For the love of God, SOMEONE help me tune my 12 string guitar! | Mike Richardson | Guitars and Basses | 20 | 08-22-2007 11:09 |
| Nylon string acoustic | Armistice | Microphones | 6 | 02-10-2004 18:17 |
| Guitar intonation | mentil69 | Guitars and Basses | 30 | 03-30-2003 11:50 |
| which nylon string guitar to buy? | wes480 | Guitars and Basses | 1 | 02-10-2002 09:35 |
| Mic for recording nylon and steel string guitar | Lucho | Microphones | 22 | 01-16-2002 14:52 |
