12V one power supply tube distortion pedal?
Is this possible? I want to build a tube-based distortion pedal but don\'t yet feel comfortable working around 120VAC supplies or, by extension, transformers. However, I do feel very comfortable with 9-15VDC and am wondering if there\'s a schematic out there for a 12AX7-based distortion pedal or if someone can point me in the right direction for designing one. I\'ve been reading up on tubes a whole lot and am starting to understand a little bit more why they do what they do. I got the heaters working with 9 and 12V last night, so that was a positive step for me. I guess what I\'m not so sure about is how much a signal needs to be amplified before it hits the tube, and what the relation between grid, cathode, and plate 1 and 2 are. From what I\'ve been reading, basically xxx 1 is where the signal enters, and xxx 2 is where it exits. So put in the signal on grid 1 and it exits on grid 2, but this obviously didn\'t work. I tried having it exit on plate 2 also and that didn\'t work either. Hell, I\'m not even sure where to feed the voltage on the plate. I\'d appreciate any guidance on this, as it\'s a very foggy subject for me at this point. Thanks!
Edit: I just found this, so hopefully I can do this tonight.
http://www.myspace.com/sundrone Last edited by timthetortoise; 10-04-2006 at 11:32.. |
Thank you for that in-depth info. I still want to use a 12AX7-based circuit, mostly because I have sockets and tubes readily available. What is the minimum voltage you\'d recommend for supplying the plates?
http://www.myspace.com/sundrone |
One other thing about that schemo, it doesn't use a 12VDC supply, it uses 12VAC and rectifies that to a +-12VDC supply. So its plate voltage is 24VDC.
If you are using a 12VDC adaptor, you will need to bias the opamp inputs . . . and make a few other changes too . . . |
| Tube Distortion Pedal... | Gr3g88 | Guitars and Basses | 21 | 11-30-2005 11:54 |
| facts about speaker power ratings | gusfinley | Guitars and Basses | 18 | 01-07-2005 15:49 |
| 48v phantom power from 12v power supply!? | fretless | Microphones | 14 | 04-26-2004 04:18 |
| Phantom Power with Tube condensor | mastac | Microphones | 3 | 03-26-2003 13:02 |
| The dangers of a bad power supply... | Slackmaster2K | Digital Recording & Computers | 12 | 11-05-2002 16:27 |
