Old 10-04-2006
sathyan sathyan is offline
Senior Member
sathyan has a reputation beyond reputesathyan has a reputation beyond reputesathyan has a reputation beyond reputesathyan has a reputation beyond reputesathyan has a reputation beyond reputesathyan has a reputation beyond reputesathyan has a reputation beyond reputesathyan has a reputation beyond reputesathyan has a reputation beyond reputesathyan has a reputation beyond reputesathyan has a reputation beyond repute
Recorder: Fostex MR-8 mkII vs MR-8 HD
I'm trying to decide between the Fostex MR-8 mkII (which uses CF) or the MR-8 HD (which has a 40GB hard drive). I'm interested a portable recording solution for two track recordings - laying down tracks which can be edited later and recording performances of 2 hours. At stereo recording time is not a big deal for me as the HD costs $400 and the mkii $250 I can add 2GB CF cards (3 hours each) for $54 and archive old material. I don't play more than 3 hours at a time.
Am I right to assume the following are the same?
- A/D chip (24-bit Sigma Delta)
- D/A chip for monitoring
- headphone amps
- analogue circuitry
- mic pres
- clean-ness of signal
- software stability
Pluses for the CF model
- can run on batteries
- quieter (no HDD)
- no HD to fail / easy to replace CF cards
- cheaper
Pluses for the HD model
- much more capacity
- Optical out
- twice the inputs
I'm leaning towards the mkII, is there any reason beyond capacity to go for the HD - audio quality I would consider a compelling reason?
Is there another product I should be considering?
thanks
sathyan
Old 10-04-2006
junplugged's Avatar
junplugged junplugged is offline
Busy Writing/Producing...
junplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond repute
i have had errors on cf cards and all flash card types that don't show up until you reach that parrt of the card that has the defect.
almost every card i ever had messed up my data at some point.
one the sd in my digital camera, i don't empty it out so i can work around the spot where 4 pics are not accessible so i never reuse that area.
i think hdd might be more reliable. not that you can't get data loss with them either, but i've had a lot more trouble with flash cards of all types so far.
i even had a messed up MD on a multitrack once.
Old 10-04-2006
zacanger's Avatar
zacanger zacanger is offline
of Angry Man Records
zacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond repute
I've got the CF version. Definitely go with the HD. You could put out for a larger CF card but that'll cost a bit, and the extra inputs really are neccessary, I hate not having them on mine.
Old 10-04-2006
daav's Avatar
daav daav is offline
Flailing up a storm.
daav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond repute
Aren't (at least the CF version) 16bit?
I had the original MR-8 CF version and the difference in quality of recordings when i went to a 24 bit comp interface were huge.
Daav
Fostex MR-8 mkII 8-Track Digital Recorder mixer hookup? SMX_Dizzy Recording Techniques 3 08-06-2006 18:46
Fostex R8 Reel to Reel recorder panicscam Analog Only 5 05-10-2003 17:30
Looking for Fostex XR-5 4 track Recorder Manual--- HLO Fostex Forum 0 01-06-2002 14:12
Tascam 414 MKII vs. Fostex x-34 orificium Newbies 0 10-04-2000 13:00
Fostex G16S recorder jeemai Fostex Forum 2 05-13-2000 01:17
