Old 10-04-2006
sloom's Avatar
sloom sloom is offline
Dedicated Member
sloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond repute
Power Amp Q for Techies:
Greetings,
I'm looking at a Crest V1500 power amp. Now there's a spec on it in it's .pdf that reads: "20Hz- 20kHz, -3dB @ 165kHz".
Where does 165kHz fit into specs for an amplifier? Cearly this can't have to do with audible frequency response? The number is in two separate pdf files for the amp. Anyone know what this means?
Thanks!
"Whatever we do, it is what it is, and we do it".
-the Grubs
Old 10-04-2006
wilkee wilkee is offline
Force of Nature
wilkee is a jewel in the roughwilkee is a jewel in the roughwilkee is a jewel in the roughwilkee is a jewel in the rough
Presumably its frequency response from 20 - 20 k must be basically flat and it is then down by 3db at 165khz.
I assume that this is at low output levels as I would not want a P.A. amplifier that coud stick out half its output at such high frequencies.
Shows a good slew rate though.
Tony
Old 10-04-2006
sloom's Avatar
Dedicated Member
I think this must be true. 165kHz is clearly irrelevant in 'real' terms, and I think the spec is there just for information sake. Just because you can't hear beyond 20kHz doesn't mean the thing isn't somehow functioning way up in that ultra-high range.
And I can't see a poweramp intended for audio not being optimized for sound for humans...
-the Grubs
Old 10-04-2006
BadAE's Avatar
BadAE BadAE is offline
Senior Member
BadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond repute
This may help you understand the spec.
Old 10-04-2006
sloom's Avatar
Dedicated Member
I'll have a look at that tonight. Thanks, BadAE.
-the Grubs
Old 10-04-2006
Harvey Gerst Harvey Gerst is offline
Huh ???
Harvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond repute
It's NOT an "irrelevant" spec. It's important to understand how the amplifier responds to fast rising signals, like a synth square wave. Cut the amp off at 20 KHz, and you'll lose a lot of the sound, turning the square wave into a nicely rounded sine wave.
Old 10-04-2006
Force of Nature
Quad made a lot of money selling amps around the world that were strictly limited 20-20k. AFAIK the jury is still out on this one.
Tony
Guitar Cab Impulse Files Keiffer Guitars and Basses 30 02-19-2008 19:41
using the same power amp for studio AND live monitors? AvoidTheClap Other Equipment and Reviews 8 05-02-2005 09:39
facts about speaker power ratings gusfinley Guitars and Basses 18 01-07-2005 15:49
Let's talk about the new VOX cerealchamp2000 Guitars and Basses 11 08-25-2004 22:27
