Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 10-01-2006
Riverdog's Avatar
Riverdog Riverdog is offline
Registered User
Riverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond repute
Korg TR61 Help
Hello and thanks for reading....
First, I need to know if someone knows how to set this thing up for sequencing... It appears you can use either the "combi" or "sequence" mode to access the system from outside the board... Is this true? Is one mode better than the other?
Last - Can anyone supply me with a Logic "environment" for the TR61?
Not a full environment just the multi-instrument setup with patches would be a great help...
Any help is greatly appreciated...
Thanks!
Old 10-01-2006
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
'Combi' is the mode you want to be in if you're using an external sequencer. 'Sequence' mode is for the internal sequencer.
Be sure to find the local on/off page and set local control to 'off'. This will break the connection between the keyboard and the sounds inside leaving you with the virtual equivalent of a master keyboard and a sound module.
Can't help with the Logic Environment --- try Googling both the Korg and TR61 as well as Logic Environments in general. It's a lil' bit of code that makes using a particular synth with Logic much easier.
...now in HD.
Old 10-02-2006
Riverdog's Avatar
Registered User
Thanks ssscientist
Thanks for the input...
I just purchased the unit and love the sounds...
But getting it wired into Logic has proved most difficult...
I can't seem to make the individual patchs in the combi change through the Logic patch selections...
But I love the "fight" with a new synth...
It's always interesting to learn something new each time you use it...
Thanks again...
Korg Tr61 bsr2002 Keyboards and Sound Modules 0 06-09-2006 20:39
Completely MIDI CONFIG Illiterate Outhabox MIDI Mania 4 03-10-2006 10:43
Korg Oasys >>> time will tell <<< Anthony Keyboards and Sound Modules 62 07-18-2005 15:55
KORG - Straight from their "Product Support" phoneguy44 Other Equipment and Reviews 0 04-23-2003 09:41
