Old 09-30-2006
tenkas tenkas is offline
Dedicated Member
tenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond repute
Soundcraft ghost : Meterbridge?
How can I configure if I want channel input or tape input monitoring, do I have to open the thing up?
Old 09-30-2006
Ford Van's Avatar
Ford Van Ford Van is offline
Banned
Ford Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond repute
Yeah, there is a jumper inside that is "global" (it effects all channels).
You could actually wire it to have an external switch.
Old 09-30-2006
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
Are you sure about that?
I had to move a jumper on every channel. I just re-read the manual to make sure I was not mis-remebering (the 90's were pretty rough for me - lol).
It was easy enough to do though. I wish I could wire in a switch to do that. Maybe the older boards are different???
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
Old 09-30-2006
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
I had to have Soundcraft fax me the instructions to solder an 8" wire in each strip. Must've been a *much* older model.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 09-30-2006
NL5's Avatar
NL5 NL5 is offline
Unpossible!
What was the 8" wire for? Switch for each channel, or did you make a global switch?
Old 09-30-2006
Switch? It was a *permanent* swap to post-fader. No switches, no jumpers. Not available on that version.
Old 10-01-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
I have the board John is talking about. The wire was to make the meters read post-fader. The stock jumper will switch the meter between channel input or tape input. We thought that was stupid, so we did the mod.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 10-01-2006
Dedicated Member
Ok thanks... I will have a look at the inside of the meterbridge
Old 10-01-2006
NL5's Avatar
NL5 NL5 is offline
Unpossible!
It's NOT inside the meterbridge - it's inside the mixer.
Old 10-01-2006
Farview's Avatar
Yup, it's on the channel strips inside the mixer.
Jay Walsh
Old 10-01-2006
Dedicated Member
ok thanks, that looks like a pain to open but I will give it a try (I don't have much experience with electronics) the thing is not even with me so I will have to wait a few months to do it! DOh!
  #12
Old 10-01-2006
Ford Van's Avatar
Banned
I guess I remembered it wrong. I bought an original version of the console and talked to Soundcraft about the mod. But hell, that was in 1997, I could really be remembering stuff wrong!
  #13
Old 10-01-2006
Farview's Avatar
Mine is a '97 as well.
Jay Walsh
  #14
Old 10-02-2006
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
You lucky bastards. Your meter bridges actually work.
Never underestimate a good analog mixer Middleman The Rack 38 09-25-2007 06:50
Soundcraft Ghost 24LE w/ meterbridge, patchbay, and cabling NL5 Free Ads for Music / Recording Equipment 27 11-11-2006 11:14
Close to Ghost - Soundcraft pres Middleman Other Equipment and Reviews 24 02-23-2005 09:45
