MIDI cable length (max?)
Anyone experiment with maximum MIDI cable run lengths? I'm thinking of setting up my keyboard in another room and this could result in a cable run(s) of up to 50'. Wondering if it will cause problems....?
Yes, I think this will most likely be too much. M-Audio has a wireless midi thing that might be what you need.
I use 25' midi cables regularly but i think 50' is pushing it
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual |
it is said that 50' is the MAX...so, I would avoid it if at all possible
I come from the taint of America, so don't bitch at me about your f*#@ing problems. You don't have to wake up everyday smelling like a mix of ass AND balls. |
Thanks guys. Wireless MIDI sounds cool, I'm gonna check that out. Got my tape measure out and it looks like 30' is about as mean as I can get (it's only slightly more than 25'....) The other option is to run FireWire instead - anyone know how far this type of cable can run?
there will be no 30ft firewire cables iknow that much, i use about a 6ft'r and all i think i saw was an 8 or 10, cant remeber which...so i dont think firewire is the answer for u....that wireless MIDI sounds pretty sweet
yeah, firewire is at most i think 4 meters, which is like 12 feet, and thats rare as hell.
maybe USB would be ok, like a powered port that you could plug into an outlet. theres plenty of MIDI-USB thingys out there.
GFCG Member: 000 029 F**k Your Scene. |
You used to be able to buy MIDI boxes which basically amplified or boosted the MIDI signal specifically for long cable runs. Philip Rees used to make one, but I don't know if they still do, and I never used one, but if you can locate one, it would solve your problem.
Orc |
Get high quality cables and you might be okay.
| MIDI guru needed elect drums soundfonts | wfaraoni | MIDI Mania | 9 | 06-19-2006 10:36 |
| Midi drum stuff for the hard of thinking: | Alan McGuinness | Cakewalk / Sonar Forum | 3 | 12-12-2002 12:03 |
| Midi cable problem | Cal D | Keyboards and Sound Modules | 2 | 11-07-2002 12:56 |
| Midi and Sound Card problem | Cal D | Digital Recording & Computers | 5 | 11-05-2002 19:50 |
| Midi and PSR 330 | Gumbylives | Recording Techniques | 0 | 07-04-2001 18:24 |
