Old 09-27-2006
tenkas tenkas is offline
Dedicated Member
tenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond reputetenkas has a reputation beyond repute
Fader pins (fader knobs) replacement
Where is it possible to find some fader knobs (fader pins) replacement for a soundcraft ghost?
Thanks
Old 09-27-2006
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
They still make Ghosts so you should be able to get them from Soundcraft.
Old 09-27-2006
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
If you are junst looking for fader caps, you could also try markertek, nutek, mouser etc...
If you need the whole fader, you may have to contact Soundcraft or an authorized Soundcraft repair center. Most console manufacturers use OEM faders that either are tapered differently than standard aftermarket faders, or are setup with different mounting distances.
Dealer for Peluso Microphones, Blue Microphones and CBI cables....
http://www.myspace.com/xstaticstudios
Old 09-28-2006
Dedicated Member
Fader Caps! That's the word I was looking for!
Thanks
Old 09-28-2006
RideTheCrash's Avatar
RideTheCrash RideTheCrash is offline
Force of Nature
RideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond repute
There are plenty of sites out there that sell them, but definitely contact Soundcraft. I've been trying to find replacements for my board, but the tang they require is sort of obscure and the company doesn't make 'em anymore. Kind of sucks, but good luck.
Old 09-28-2006
Fader caps are generally pretty universal, the faders themselves however are anything but. If you do get just fader caps from soundcraft, you will probably pay 3 times as much if not more.
Automation EQ and Automation manually walters Mixing / Mastering 22 08-18-2006 21:50
Replacement fader knobs RideTheCrash Other Equipment and Reviews 1 03-17-2006 16:33
replacement knobs? j dubb Guitars and Basses 6 04-03-2004 12:38
replacement knobs for the audio buddy? Alaking The Rack 2 07-16-2003 02:18
Difference between SEND and INSERT in cubase Gabriel Sousa Digital Recording & Computers 4 01-27-2003 12:48
