Any thoughts on the Apogee MiniMe??
anyone used the Apogee MiniMe, mic pre? i want to get something so i can use the S/PDIF i/o on my Digi002.
worth it/not worth it? alternatives? i'd love to have the name Apogee in my studio too, which is part of the reason. hit me.
GFCG Member: 000 029 F**k Your Scene. |
thoughts? sweet; it's nice that you're not trying to run it through the usb alternatives: http://www.blacklionaudio.com/digi002_mod.html but you'd have to give up your rig for a while and the scuttlebutt is that bla takes a while sometimes. personally i'm trying to get the analog side of my stuff right first and then go hard after the digital. it just seems like the digital is going to turn over ever few years anyway. the mini-me pres are supposed to be good though!
SPACE AVAILABLE FOR RENT |
The MiniMe is still (IMO) one of the greatest bargains in audio, period.
And the UAD collection of plugs... Although - I have to admit, if I were looking for a unit with those capabilities, I'd have to try that new API rig before I spent the cash... I have a MiniMe and for what it does, it does it well. But that (API A2D) thing looks awfully tempting - especially at that price point... |
thanks for the thoughts guys, i'm going to look into those two things too!
i figure that technically, nothing is analog anyway.. either way, it's going through firewire into a computer, making it digital in the end..
plus if something were to break after it, would i be able to point my finger at them?
I have looked at the MiniMe many times and wished that I had the scratch for one. I always thought that for mobile stuff, I think this unit would be great for 2-tracking.
i looked up the API unit on SoundPure- there price is around $1700, a little under.
a little too rich for my blood. nothing's definite yet, im keeping some options up here.
i've got a minime and i like it a whole lot.
the mic pres are clean, clear and at the same time pretty "big" sounding. a lot of times people think "thin" when they think of "clean and clear". i find they excel on things like acoustic guitar and drum overheads, you know, places where i typically want clarity and transient response. at the same time, i don't hesitate to use the preamps on things like vocals and electric guitars, when i want the sound that the minime's pres give me. i haven't tried it on snare/kick, simply b/c i've been using it on OH's when i record drums. the compressor/limiter is quite nice as well. the first setting is subtle but noticible (i usually leave it on, actually), the 2nd setting is a bit more aggressive and the 3rd is pretty extreme. playing a DI'd guitar through the 2nd and 3rd comp settings can really be a LOT of fun--you can get some great spank and sustain out of it....makes a DI'd guitar sound a lot less DI'd, if that makes any sense. also of great use is the clock. i've got my delta 1010 clocked to it, and it makes a HUGE difference in the 1010. the low end tightened, the highs softened (became less harsh) and the mids got this creamy presence to them (as opposed to being grainy and in your face) they never had before.......which says to me that the converters in the 1010 are plenty fine, but that the clock could certainly use a little help. i've used the USB option a couple times in the field, and it's worked just fine. no complaints there either. certainly a lot more secure than some of the firewire devices i've encountered in the past. a couple nitpicks: the silkscreening doesn't *quite* line up with knob on the sample rates, etc. the phantom power can't be turned off without turning the unit itself off. the gain is very sensitive and it's easy to dial in a little too much--which goes hand in hand with my gripe about the metering.....4 LEDs just isn't precise enough--there's a BIG difference between the bottom (-40) and the next one up (-12). i think you could certainly do a lot worse than adding a minime to your setup, especially if you can find a good $$ on a used one. and, as you said, being able to say "apogee conversion" to clients sure carries a lot of weight--even if it's only 2 channels and even if it's only on the a/d side of things. cheers, wade PS--yes, i know that Mytek, Prism, etc., converters are considerably better and more highly regarded.....but i do wager that if you were to give the typical client a list of converters and asked them which one they "thought was best", i betcha you'd find apogee near or at the top of the response chain more often than not, simply b/c everyone's heard the name.....for better or worse..... |
Really. BTW, the Minime is a good product, but I hate the format. |
i can see why that would be obnoxious to some, though. ![]() oh yeah, one more gripe........the USB is not bus powerable from a laptop. grrrrrrrrrr. cheers, wade |
#12
Also, on the downside... the USB is version 1.0, if anyone assumed it's 2.0 which can mean anything from performance to compability issues.
#13
![]() in the same vein, the most you're pushing through the USB is 2 channels of 24/96.....which means you should NOT run into bandwidth problems at all. cheers, wade |
#14
No, but maybe latency? In whatever the case, it's the weak point of the product IMO, and not a standard you'd expect from Apogee, since the 2.0 protocol was out well before the Minime launch.
#15
i concur that they should have gone with USB 2.0, even if it meant pushing back the launch and doing a little more testing before release.
fwiw, though, i haven't noticed any latency at all. of course, when i use the USB, i'm running it on a really fast laptop (dell D620--dualcore 2.0, 1gb of ram). that said, i've used the USB literally a handful of times. the majority of use the minime sees is via the SPDIF out, going into my Delta 1010 card. and again, there's no latency to speak of......FWIW, the analog inputs of the 1010 are FAR more latent than the minime. cheers, wade |
#16
the minime gets a solid...MEH from me.
I dont like apogee conversion, and there are much better all in one boxes around..(lunatec v3 for one)
http://www.capitolflags.com/images/c...ebel-small.gif |
#17
i dont care at all about the USB, im pretty sure they make a unit w/o it for a little less.
i want it for s/pdif. i've never heard apogee conversion, so i cant say. can i tell the difference anyway... not at the moment.. give me a couple years maybe?
| Apogee MiniMe or other 192khz DA device question | kennycarvajal | Mixing / Mastering | 4 | 01-12-2006 22:52 |
| Your thoughts on Apogee mini-me | Herr Joachim | The Rack | 4 | 01-11-2006 19:24 |
| Any DM24 users with an apogee ad16x, How to connect? | rcktdg | TASCAM User Forum | 0 | 08-31-2004 04:31 |
| A/D D/A converter upgrade thoughts | Michael Jones | The Rack | 9 | 07-06-2003 16:13 |
