Old 09-25-2006
bair_ohio bair_ohio is offline
Junior Member
bair_ohio is on a distinguished road
Question Multiple Mixers--multiple amp question
Ive got a Mackie Board that the theatre uses for live sound, Ive also got a seperate board in the booth for PC sound. My question is this.
Can I hardwire both into the amps without running in to problems?
Basically, I want to run them(mixers) indpendantly but use the same amps.
Any direction here would be appreciated.
Toshiba Satelite-3.06 Ghz-Multimix 16 Firewire-M-Audio StudioPhile BX8's
Silo The Huskie
Sinister Jim
Old 09-25-2006
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
Yes, you should be able to do that just fine. The biggest problem I see is the obvious one... You will have two people mixing to the same system with independent controls. Why not just run the PC mixers outputs to the other console? Or vice versa...
Dealer for Peluso Microphones, Blue Microphones and CBI cables....
http://www.myspace.com/xstaticstudios
Old 09-25-2006
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
There's a couple ways to do it that come to mind:
1. Submix the outputs of both mixers and send that to the amp. So you'd need a very small mixer for that.
2. Send the master output of one of the mixers into the other mixer and then go to the amp from that mixer. Routing this would not be difficult, you could go into an aux or buss return, for example.
What I would *not* do is connect the outputs of each mixer by hardwiring them together.
http://www.misterpotts.com
Old 09-25-2006
Junior Member
The main idea here is to have complete control from either mixer.
mixer A is only used during live band situations.
mixer B is only used during theatre performances.
As is stands right now, the A mixer runs through a channel in mixer B then on to the amps. The pain here is that you must go to the booth and set the mixer(B) to the proper level. This just complicates things.
does this make sense?
Silo The Huskie
Sinister Jim
Old 09-25-2006
Then you just need a little summing box. Run the outputs of both mixers into the summing box and then straight to the amp.
Any decent little mixer should work, but there are also summing mixers designed for just this kind of task.
Old 09-25-2006
RAK's Avatar
RAK RAK is offline
Manufacturer - Shure, Inc
RAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond repute
So you've got the same amps powering the speakers in the house, and the speakers in the booth?
Are you going to leave mixer B in the booth for theater performances and not mix that from the house?
Originally Posted by jimmy2sticks
For the record, I am smarter than Einstein.
Old 09-25-2006
All you really need then is some sort of switching device since you will not be simultaneously using both consoles. In fact, you could literally just "Y" the two mixers together, get a samll mixer to combine/switch with, manually replug etc... All of which seem simple to me.
Old 09-26-2006
I don't think switching is necessary. Both mixers can be active all the time if they are being submixed by a third small mixer.
Old 09-26-2006
My suggestion for a "switching device" was meant to be the small mixer, or in place of one
Old 09-26-2006
Junior Member
Just to make clear. I would like to set this up so that whether your doing live band sound or theatre sound, No one would have to touch a mixer beyond the one they are working with. Thats why I was thinking about hardwiring both mixers direct to amp.
Maybe what I should of asked was,
Can I run two seperate mixers directly in to a single amp?
Silo The Huskie
Sinister Jim
Old 09-26-2006
Yes, you can. It just isn't the greatest of ideas.
Alan... No Stephen Paul Mic? DJL Microphones 249 07-27-2007 23:47
an odd amp question little guy Guitars and Basses 33 07-26-2005 14:26
Question for all you obscure Marshall Amp gurus NL5 Guitars and Basses 10 05-22-2005 15:05
silly question on guitar amp volume philpereira Recording Techniques 7 05-20-2005 11:56
Noob question about mixers luckystrike Recording Techniques 5 03-12-2005 13:28
