Old 09-21-2006
dzara 4 dzara 4 is offline
Junior Member
dzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond repute
balanced A/C power
I just purchased a 200 dollars monster power conditioner which did not eliminate low hums and hisses. Recently i have been doing more and more research on ac noise and a lot of places suggest
using balanced power will get rid of all hums ,hisses , etc. I was wondering if
any one had a balanced ac power conditioner and how effective it actually is in reducing unwanted noise(is it worth spending 1500-2000 bucks).
thanks
Old 09-21-2006
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
What gear do you have that is noisy? That may be the easier and cheaper way to address the problem.
Old 09-21-2006
littledog's Avatar
littledog littledog is offline
Three Thousand and Counting
littledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond repute
If your power was already pretty quiet, you may not notice any improvement at all by balancing it. Unbalanced power is only one possibility among many for what is causing electronic noise in your studio. In some cases it can help, but it is not a magic bullet that fixes everything.
Old 09-22-2006
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
I use balanced power and it does help, but it won't magically eliminate all noises. Some it reduces more than others. Although overall I do believe it's a good idea.
That Monster unit you bought is really just a fancy power strip with some filtering, not a power conditioner.
http://www.misterpotts.com
Old 09-22-2006
RAK's Avatar
RAK RAK is offline
Manufacturer - Shure, Inc
RAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond repute
How about trying an Iso Transformer?
Also did you trying turning lights off and see if that helps? Are you using any TS or RCA cables you can switch out with XLR or TRS?
Originally Posted by jimmy2sticks
For the record, I am smarter than Einstein.
Old 09-22-2006
Robert D Robert D is offline
Close to the Edge
Robert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond repute
BTW, hiss is usually not affected one way or the other by power conditioning or lack there of. Hiss is generated by all active circuits to some extent, and is amplified by each successive gain stage. Problems with hiss usually result from improper gain staging, where one gain stage is doing too much work. A classic example is if you have a mixer channel with the gain or trim up high and the channel fader up high, and then the main buss fader or power amp volume low to compensate for it. Proper gain staging will eliminate excessive hiss on all but the cheapest of todays recording equipment.
Oh, I made the assumption that you're not talking about tape hiss.
Regards,
RD
http://www.myspace.com/twentysevenmoons
Cables: XLR vs. TRS, Balanced? guitar roy Microphones 15 05-06-2003 21:47
John, AC Power info... knightfly Studio Building & Display 4 05-23-2002 11:50
Balanced Ac Power Opinions MERRICK Other Equipment and Reviews 2 12-05-2001 19:53
Help!! - Double Phantom Power ?? Carlos Microphones 13 05-26-2000 09:42
