Old 09-19-2006
Sir_Burn_Alot Sir_Burn_Alot is offline
Newbie
Sir_Burn_Alot has a little shameless behaviour in the past
Eurotrack UB802 Mixer settings?
I'm using this mixer with Cool Edit Pro 2.0 and I'm not sure on how what to set the knobs to. I know how to work everything inside of Cool Edit Pro. I just need to know what should I set my mixer to? How do I determine where to set each knob?
Old 09-19-2006
turnitdown's Avatar
turnitdown turnitdown is offline
$10 PayPal=Your Ad Here!!
Location: Foothills of the Sierras, Northern Calif. USA
turnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these parts
To do what????
Is this a test question????
If Bruce Springsteen is the Boss.... I quit.....
Oh, and PMC#11 8th place winner!!
Learn the scary truth about "The Religion Of Peace"... click here
Old 09-21-2006
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
Plug your microphone into channel one on the mixer and turn the phantom power on. Then sing or have someone else sing into the mic while you bring up the level on whats labeled the 'gain' which is meant to get you in the rough ballpark.
Once you see the the levels in Cool Edit do the fine tuning with the level knob at the bottom of the channel strip. You may need to reset the gain so that the level knob is about in the middle.
...now in HD.
Mixer hookup question Giganova Mixing / Mastering 7 06-29-2006 09:54
Recording via mixer into soundcard Brendon Bussy Recording Techniques 4 06-17-2006 08:26
What is the noise floor on your Delta? canada-paul Digital Recording & Computers 30 05-27-2003 06:59
Help! How to route my mixer so I can monitor effects using my computer kelitupu Newbies 3 05-10-2002 01:38
my recording setup - NEEDS HELP sykotic Digital Recording & Computers 12 10-06-2001 17:26
