Old 09-15-2006
XTREEMMAK's Avatar
XTREEMMAK XTREEMMAK is offline
The Eccentric Listener
XTREEMMAK has a reputation beyond reputeXTREEMMAK has a reputation beyond reputeXTREEMMAK has a reputation beyond reputeXTREEMMAK has a reputation beyond reputeXTREEMMAK has a reputation beyond reputeXTREEMMAK has a reputation beyond reputeXTREEMMAK has a reputation beyond reputeXTREEMMAK has a reputation beyond reputeXTREEMMAK has a reputation beyond reputeXTREEMMAK has a reputation beyond reputeXTREEMMAK has a reputation beyond repute
Red face Studio Room Treatment and Suggestions
Hi I'm actually new to studio construction and room acoustics but I have a studio that is currently located in my second floor loft.
I'll try to answer all the questions I need to answer as best as I can. Well lets see...
I'm currently located in South Florida, Miramar. No additional construction either than what you see here has been made and we really haven't taken research into consideration for planning and development (floor risers, wall treatments, paralel walls?) considering I dont actually know where I could or need to start. A little bit about the room though, considering the closness of the speakers and the type of speakers they are, we dont get a very big deal of sound reflection coming back depending on the volume, considering we are on the second floor loft, we do however have the disadvantage of the sound interacting with the entire downstairs.
Neighbors arent an issue at all and outside sound and noise isn't a problem at all either. What I'd like to do is clean up this sound situation. Considering that this is the only available (and affordable) location we can acquire right now, we really have no choice. I would buy some foam and put on the walls but I dont know where I'd put it. The couch makes a good bass trap. How well of one I dont know. Also I dont know if Bass is being grouped in other locations either. As far as reflection recal, when I snap, I'd say it takes a reverb release about 1.6secs to be unnoticable (almost irelavent but w.e.).
Here's the actual floor plan of the upstairs:
As I said before, no additional constructions has been made prior to when the actual house was build. No power conditioning, inner or outer wall treatment, or floor treatment.
What was suggested to me is:
A. Get some wall (Aralax) foam and either do it your self put the foam or call the support team in for help.
B. Get some partitions (like what you see in business areas) and put it behind me. Then add the Aralax foam to the partitions.
I'm not sure which would seem the most effective. The other idea I thought about is that I can keep the project studio as I have it now, (some of you may suggest to add something to the closer speakers?) and change my room into the mixing room A.K.A. Studio B:
Then I'd just do the treating and adjustments that if you can suggest, to this room.
These rooms are in close proximaty to each other and are both upsairs.
Much help needed. I appreciate your input. Thanx
Edit: Ohh last thing.
As far as our Budget, well the studio is split between 3 investors so in about a 3 to 4 month span we could push out probably about $2000 more or less depending on what would need to be done.
Old 09-16-2006
Seeker of Rock's Avatar
Seeker of Rock Seeker of Rock is offline
InLovingMemory..EZ_Willis
Seeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond repute
Shit man, first off I love your house. That is a great floor plan. Damn, just when I was happy with my little 1500 square footer. I'm just up the road from you in Hollywood, btw.
I think why you haven't gotten a lot of responses is there is a lot of info already in here on this subject. Go to www.johnlsayers.com or www.ethanwiner.com and you can find more good info. There was another really good thread from 2001 that was revived a few months back...what was his name again, frederickp I think the thread name was studio construction suggestions or something like that. Anyway, do you plan to wall off the loft? Probably not would be my guess. Are you recording amps and drums, or going straight into something/using programs? Typically in here 703 rigid fiberglass insulation is what is recommended for 'treating' walls, but that is usually in a confined space. With an open loft, I'm not sure that everything you read is going to be applicable. Do a search in this forum, hit the sites I gave you above and you will have a better understanding of where you need to go. If all you plan to do is look for wall treatment and not really build a 'studio' per se, then you should probably figure out where your acoustic problems are first, then you'll better understand what you need to do to remedy them.
My girl there are just some things that aren't done...like drinking Dom Perignon '53 above the temperature of 38 degrees Fahrenheit
Old 09-19-2006
XTREEMMAK's Avatar
Thank you for the compliment btw. I'm not trying to get rid of the loft but I'll read those links that you gave me (I love Hollywood Florida. I'd like to live there again someday if possible ). I know it's impossible to sound proof a loft and situating the sound could be a bit difficult, but I'll see. If anything like I said I'll have to make another room totally devoted to mixing.
BTW: Just installed a hanging 17" flat screen second monitor to replace that one on the side .
Question on Room treatment thegatekeeper Studio Building & Display 19 01-13-2006 13:15
Suggestions for treatment of very unusual room Capt Dunsel Studio Building & Display 37 03-29-2004 18:28
Inexpensive room treatment Jute Studio Building & Display 4 05-24-2003 23:10
First Adventure into Room Treatment Chrisjob Studio Building & Display 32 05-14-2003 07:40
Tracking room roof treatment sjoko2 Studio Building & Display 1 03-12-2001 11:59
