Interesting Converter Comparisons ...
Alright, so I have, in my posession, three different types of converters.
I have what many would consider to be a mid-level consumer / prosumer audio interface. I also have a stand-alone a/d converter that many would consider to be a pretty high end / expensive piece. Also in my posession is an el-cheapo stand-alone consumer A/D converter. For fun, I decided to do what I consider to be a valid comparison of the three units. What I did is take an existing rough mix of one of my clients, and I ran it through each converter. Four times. Each time, I used the exact same D/A. The idea, again, is to test the differences in the A/D. Levels have been matched pretty well. Signal path, in each case, has been kept as simple as possible. Each one used it's own clock, because I feel that to be an important component of the converter and should be part of the comparison. Anyway, you can find the files here: http://www.nowhereradio.com/artists/...3503&alid=1578 Honestly, guys, I think it's pretty damn interesting. I've always felt that comparing converters was a pretty hair-splitting exercise, and I think this comparison lends credence to that. After 4 generations of A/D, you should be able to start hearing some of the degredation that each converter imparts to the audio, and you should start hearing what each unit brings to the table. . |
Hairsplitting indeed. I'm going with #2 sounding best, but don't ask me why.
option 4 - they all sound like crap.
It's hard to tell from those examples as the air is pretty much non-existant, and the top end is pretty well hosed in all of them. Bad mp3 conversion maybe?
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F. |
so did you finally see the light?
It is easy to hear the difference between sample1, and samples 2 AND 3.
In other words, Sample1 is clearly inferior to 2 and 3. Where it becomes and issue of hairsplitting is between 2 and 3. If i had to choose quickly, i would select sample 3 as the best. The difference between sample1, and the others is pretty big (relatively speaking!), so i cant really see the validity in blaming mp3 conversion for not being able to hear stuff. Interesting test. |
So you hear "air" in those samples? You think the highs sound fine in those samples? Where did I say I couldn't hear a difference? You are the one that said 2 and 3 were too close to call....... edit - and for the record I'm saying the are in order 1,2,3 - Guessing 3 is not exactly "high-end" though. Also, I am not here saying converters will make or break you. I do think they make as much, probably more, diffrence than preamps. But, If you really want to be humbled, pick up Joshua Judges Ruth by Lyle Lovett - recorded straight to 16 bit converters from the late 80's early 90's - not exactly High end by todays standards for sure. That album sounds flippin amazing......
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F. Last edited by NL5; 09-14-2006 at 11:52.. |
i hear some rice crispy type stuff going on in 1 but I doubt that anyone that was'nt looking for such things would ever notice it. i don't hear a great difference in the 3 samples. i took a few quick listens and i'm going to listen some more, just to see.
on the tom hits in the intro, i hear a slight difference in the "crispies" in between 2 and 3. 3 having slightly more crispies than 2. what are these "crispies" called?
3 is best, 1 is second, 2 is worst. But I cheated
Didn't listen to 3 though. |
#12
i heard someone talking at around 1:27. might want to get rid of that chess.
#13
#14
#15
other than the crispies, i don't prefer one over the others. what are you guys basing your preferences on? don't be a smartass and simply say "sound". if i sit here all day long and listen over and over, i may develope a slight preference but what's the point?
#16
I based mine on the cymbals sounds, the squeaks from the guitar player, and the tom hits mainly........
#17
#18
#19
#20
#21
#22
When are you going to tell us which one was which?
#23
Listen for clarity, stereo imaging, and compare transients (i.e. drum/cymbal hits etc). |
#24
I wasn't attacking the mixes - just the use of them for a test of this nature. Sorry if it seemed a bit harsh......
#25
I say if you have to actively listen to the samples to tell a difference, especially after being sent through the converter 4 times, then they all must be somewhat decent.
| Digimax Converter Question | Bobalou | Digital Recording & Computers | 1 | 05-19-2004 03:24 |
| Harmonics from D/A converter. Normal? | Industrial | Digital Recording & Computers | 0 | 03-31-2004 01:15 |
| Sonic Solutions A/D converter | Chip Hitchens | The Rack | 6 | 03-25-2004 14:47 |
| mic pre needed for an A/D converter? | hk_runner | Recording Techniques | 15 | 05-09-2002 00:07 |
| Converter question | maddrummer | Other Equipment and Reviews | 0 | 03-11-2002 13:39 |
