I'm retarded tonight...does Shinybox have a pre?
I've seen one on their website, but no price...
Bodhisan
What if the movie had been Edward Microphonehands instead of Scissorhands? |
it looks like that pre was the product of some custom work. is it possible you've been hearing the buzz about this: http://www.wesdooley.com/aea/TRP.html ?
SPACE AVAILABLE FOR RENT |
If you don"t have enough Gain in your preamp to run a Ribbon mic you could build a simple Preamp inside the Mic body it"s self to boost the Gain by up to 20db and Phantom powered so you wouldn"t need a seperate power source....
That is if you have some electroniX skills.... Cheers
M-Audio Delta 44 + Delta 1010LT 5 Piece Drum Kit w6 Cymbals Custom Made Bass Guitar Custom Made Les Paul Guitar Mackie Traction Studio 2.1 P-4 PC w 512mb DDR 80gb HD Sell you used Equipment Here: http://www.proaux.com/phpprobid/index.php |
Well you could use something like this:
![]() But instead use lower power transistors ...The curcuit might work the way it is but at a Lower gain level and you might have to add a Zener as a Voltage regulator to get the Voltage down to 15v to 18v.....also lower the Value of the output resistors to maybe 100r so you get a Lower output impedance and Match the Transistors as best you can to each other....It would probably be best to add it after the output transformer of the Ribbon but it is possible to add it in between the Mic curcuits and the Output transformer.... Cheers PS: I actually just realized the above circuit needs a +/- supply and Phantom only supplies + but the Circuit could be modified to run off of a single supply...
M-Audio Delta 44 + Delta 1010LT 5 Piece Drum Kit w6 Cymbals Custom Made Bass Guitar Custom Made Les Paul Guitar Mackie Traction Studio 2.1 P-4 PC w 512mb DDR 80gb HD Sell you used Equipment Here: http://www.proaux.com/phpprobid/index.php Last edited by Minion; 09-14-2006 at 16:27.. |
| The ULTIMATE Entry-Level Mic Pre Poll... :op | WATYF | Microphones | 349 | 21 Hours Ago 18:51 |
| Mic pre around $1000. Hrm, didn't ever think I'd post one of these. | Chris. | The Rack | 40 | 04-07-2006 22:17 |
| Tibe Mic solid state Pre vs Solid State Mic and Tube Pre | homestudioguy | The Rack | 15 | 01-19-2006 07:30 |
| Pre Amps | CP2 | Microphones | 13 | 01-06-2004 21:12 |
| mic pre into mic pre??????? | dean666 | The Rack | 12 | 12-04-2003 17:36 |
