Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 09-13-2006
mixaholic mixaholic is offline
Senior Member
mixaholic has a reputation beyond reputemixaholic has a reputation beyond reputemixaholic has a reputation beyond reputemixaholic has a reputation beyond reputemixaholic has a reputation beyond reputemixaholic has a reputation beyond reputemixaholic has a reputation beyond reputemixaholic has a reputation beyond reputemixaholic has a reputation beyond reputemixaholic has a reputation beyond reputemixaholic has a reputation beyond repute
gain reduction when mastering
what is a good gain reduction level when compressing during mastering. i pretty much know about 6 db gain reduction or a littl less is good for vocals. thanks
Old 09-13-2006
bblackwood's Avatar
bblackwood bblackwood is offline
Senior Moment
bblackwood has a reputation beyond reputebblackwood has a reputation beyond reputebblackwood has a reputation beyond reputebblackwood has a reputation beyond reputebblackwood has a reputation beyond reputebblackwood has a reputation beyond reputebblackwood has a reputation beyond reputebblackwood has a reputation beyond reputebblackwood has a reputation beyond reputebblackwood has a reputation beyond reputebblackwood has a reputation beyond repute
Whatever sounds best...
That being said, I rarely do more than 1dB GR.
Brad Blackwood
euphonic masters
Old 09-13-2006
VTgreen81's Avatar
VTgreen81 VTgreen81 is offline
Dedicated Member
VTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond repute
I don't think you can use a rule of thumb like that. -6dB may be good for one voice, another may be able to handle -15-20dB. as far as mastering I'm clueless, but I'm sure it'll depend on the track and the producer's ear.
Have a wonderful day........................and make someone else's day wonderful too
Old 09-13-2006
masteringhouse's Avatar
masteringhouse masteringhouse is offline
www.masteringhouse.com
masteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond repute
Second that. There are no rules for compression/limitng and it varies greatly among engineers.
Compare your results with a reference that you respect and let your ears be the guide.
Tom Volpicelli
The Mastering House Inc.
MySpace:
www.myspace.com/masteringhouse
Old 09-13-2006
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
Start with your attack and release both set to "auto". If either of them does not have an "auto" function, set them both to medium speed. Start with threshold set to 0dBFS (or the analog equivalent) and a compression ratio of 1:1.
That is often a very good setting for mastering the two mix. You can always tweak from there.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 09-13-2006
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
I'm in the "whatever works for the mix" category - Rarely more than a dB or 2 on compression. If limiting is involved and the clients is looking for "stun" volume, perhaps a bit there also.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 09-13-2006
Robert D Robert D is offline
Close to the Edge
Robert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond repute
G.
That's a little extreme, isn't it Glen?
Regards,
RD
http://www.myspace.com/twentysevenmoons
Old 09-13-2006
Actually it's starting right down the midde; no compression, no expansion. Tweak from there as needed.
It's just a smart-assed way of saying the same thing Brad, Tom and John have said; do what the mix needs.
At the very worst, it's no less accurate of a place to tell someone to start than any other number that can be put out here.
G.
Glen J. Stephan,
Old 09-13-2006
Close to the Edge
Yeah, I got that. It's always pissed me off that most efx plugins and program resident efx launch with other than a neutral initial or default state.
Regards,
RD
Old 09-13-2006
It does make me wonder...
It's probably more of a rarity these days, but I'd be curious to hear Tom, John and Brad respond to this: When was the last time, if ever, that you applied expansion instead of compression to a two mix to breathe life back into it instead of squashing it out?
G.
Glen J. Stephan,
Old 09-13-2006
bblackwood's Avatar
Senior Moment
Never - expansion doesn't do a very good job of that, imo...
Brad Blackwood
euphonic masters
  #12
Old 09-13-2006
Same here. I've tried a little "transient modeling" (SPL, etc.) with mixed results, but mostly just mixed.
  #13
Old 09-13-2006
flatfinger's Avatar
flatfinger flatfinger is offline
Use every dam bit!
flatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond repute
Why are you compressing the 2buss? is it to get the RMS up??? Or do you really want to change the inner structure and make the softer stuff more prominent? Be sure to use a soft knee ( and program dependancy if it's available) if you want to keep it less obvious.
  #14
Old 09-14-2006
I've tried using the upward expander from the Waves Linear-Phase MultiBand.
Eh, not great.
Once transients get thrown out the window you can pretty much wave goodbye IMHO. I usually try to get a remix/unsquashed version before trying to add prosthetics.
Tom Volpicelli
MySpace:
  #15
Old 09-14-2006
Brad, John and Tom, thanks for the rapid replies. That's pretty much what I figured, but it was a thought that crossed my mind and got me wondering. Thanks .
G.
Glen J. Stephan,
  #16
Old 09-14-2006
Actually G's technique is close to the one that I use.
There are generally 2 ways I approach compression. First I decide if it's transients that I want to reduce, or if I feel the music needs more average level/add density.
If I'm going for transients I will use a high ratio (10:1 or more) and start with a threshold at 0dBFS lowering it until I find where it get at a level where I want the comp/limiter to react. Attack/release settings are set to something that reacts very quickly.
For averaging I'll use a technique similar to G's and start at a threshold of around -10 dBFS (or wherever the average level seems to be at) with a ratio of 1:1 gradually increasing it until I get the desired effect. Attack and release settings are slower for this.
Please keep in mind these are only starting points, from there I'll adjust attack/release listen to the results and make adjustments from there including gain makeup.
Tom Volpicelli
MySpace:
How to use Waves X-Noise (noise reduction) properly? quietb03 Mixing / Mastering 3 07-27-2006 17:11
DSD Primer BigRay Recording Techniques 0 01-07-2006 10:39
recording hiphop vocals...and compression ? johnnypraze Recording Techniques 3 07-26-2004 00:45
Please Help!!! Girlnezz Cool Edit Pro / Adobe Audition Forum 28 06-25-2003 14:18
Preamp input gain problem? muser Microphones 3 02-01-2003 13:20
