Go Back   Home Recording > General Discussions > DJ & Hip Hop Production
Reply    Audiofanzine Dj Dj News Dj Medias Dj Tests Dj Articles Dj User Reviews Dj Classifieds Ads
Old 09-12-2006
Fyre's Avatar
Fyre Fyre is offline
Mr. He About His Paper
Fyre has a reputation beyond reputeFyre has a reputation beyond reputeFyre has a reputation beyond reputeFyre has a reputation beyond reputeFyre has a reputation beyond reputeFyre has a reputation beyond reputeFyre has a reputation beyond reputeFyre has a reputation beyond reputeFyre has a reputation beyond reputeFyre has a reputation beyond reputeFyre has a reputation beyond repute
battery 2
anybody got experience wit this program.. i just got it and its helped a lot with my sampling but the problem now is that cant figure out how to change the pitch of a sample with out changing the tempo... i tried doing it thru fl but that doesnt work..... any help with this would be appreciated
thx
Old 09-13-2006
Fyre's Avatar
im guessing no one uses this prog lol
Old 09-13-2006
L'espion Noir L'espion Noir is offline
Force of Nature
L'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond repute
i have battery 1 which i haven't used for a minute but if 2 is anything like mine
everything is controled in the envelop
Old 09-13-2006
Fyre's Avatar
i dont kno how much like 1 part 2 is put ill check that out tho
Old 09-13-2006
DesertEase DesertEase is offline
Notorious
DesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond repute
I had Battery2 once..... lol
Old 09-14-2006
onlydude onlydude is offline
Dedicated Member
onlydude has a reputation beyond reputeonlydude has a reputation beyond reputeonlydude has a reputation beyond reputeonlydude has a reputation beyond reputeonlydude has a reputation beyond reputeonlydude has a reputation beyond reputeonlydude has a reputation beyond reputeonlydude has a reputation beyond reputeonlydude has a reputation beyond reputeonlydude has a reputation beyond reputeonlydude has a reputation beyond repute
Never used battery 2 but from my research personaly, there really isn't a way to change the pitch without changing the tempo (or none that I know of). Thats just how things are. But, what I will do sometimes, is if I want a sample a different pitch I will change the pitch in sound forge and then time stretch it back to its origional timing. But time stretching only works to an extent, and it may skrew up your sample prety bad if you over use it.
Old 09-14-2006
mentalattica's Avatar
mentalattica mentalattica is offline
Just a Home Recorder
mentalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond repute
You can easily change the pitch without affecting the tempo in most programs, I use audition but have seen it done in cubase sx3 and acid.
It's called a time stretch, in audition you can adjust the pitch and keep the same tempo. After applying too much it starts sounding nasty, and not in a good way. Cubase's pitch shift works the same way and from what I remember it's a lot more stable than Auditions (meaning you can push it more). Battery should have the same feature I suppose, maybe under a different name or something.
Old 09-14-2006
Fyre's Avatar
since i have audition i might have to go back to chopping up samples there........ thankx for the info guys
ensoniq sq-1 how do i change this battery rokinrandy Keyboards and Sound Modules 13 12-02-2006 14:19
HR16 and SR16 battery trivia soundchaser59 Alesis Forum 6 03-13-2006 09:47
Recording Battery in Cubase SX3 stabmasterflex Cubase User Forum 8 12-26-2005 14:20
Pops and Clicks using Battery with SX trogdor Cubase User Forum 0 05-14-2003 13:44
Sonar -> Battery -> Drumkit From Hell -> advice needed tubedude Cakewalk / Sonar Forum 3 02-25-2003 13:22
