Old 09-12-2006
kojdogg's Avatar
kojdogg kojdogg is offline
bollocks redux!
kojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond repute
barrier strips?
anybody actually use these on gear? my dbx 160x's have these on the back and i'm wondering if there is any advantages to using them (do they allow for balanced signal connections?) i've seen adapters on markertek:
http://www.markertek.com/Product.asp...&search=0&off=
can i just connect an xlr to that and screw the adapter onto the back of the 160x?
tia for any help.
SPACE AVAILABLE FOR RENT
Old 09-12-2006
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
That's a clever little adapter, I'd not seen that before.
I don't mind barrier strips at all, but I make my own cables. You build one end as usual and on the other you put the little "y" connectors (is that what they are called?). Then you just screw the appropriate wire to where it should go on the barrier strip.
http://www.misterpotts.com
Old 09-12-2006
kojdogg's Avatar
bollocks redux!
thanks for the info! do you know of any advantage to using them as opposed to just running an xlr into an unbalanced input?
cheers,
koj
Old 09-12-2006
mrT's Avatar
mrT mrT is offline
Force of Nature
mrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond repute
I think it's a spade... could be wrong. That's what I'd call it at least.
Dishonest lifelong misspeller and theif...
Graphic
When Your Horse Dies, Get off It...
-David Petrie's tomb stone.
Old 09-12-2006
Right, a spade. Thanks!
When I had my 160X's I just used the 1/4" connector. Sounded fine to me.
I think at that time, probably around the late 70's, the barrier strip was actually included for compatibility purposes, since that was a standard connector back then.
The only time I use barrier strips is when I don't have another option. If the gear has both barrier strips and 1/4" or XLR I'll use whatever connector is most convenient, which is usually going to be 1/4".
Old 09-13-2006
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
The only real problem with barrier strips that I know of is the inconvenience. Barrier strip does not denote balanced though. They may be either balanced or unbalanced. They are handy for trouble shooting though. It makes it easy to see if there is a problem at a given location.
Dealer for Peluso Microphones, Blue Microphones and CBI cables....
http://www.myspace.com/xstaticstudios
FS: Yamaha PM1000 Channel Strips Wired Jrasia Free Ads for Music / Recording Equipment 3 06-30-2006 08:53
Quad cable for barrier strip... vcgeetar The Rack 2 05-18-2006 14:43
using channel strips on live gigs? earworm Live Events 2 06-06-2005 07:13
Trident Fleximix channel strips xstatic Free Ads for Music / Recording Equipment 2 03-30-2005 09:30
Can you create an alternative to vinyl barrier? ob Studio Building & Display 10 10-27-2002 20:02
