Phantom power with PG81
My church has a bunch of microphones. The new one is a PG81. The others are older, and look similar (but silver); I'm not sure what they are exactly. They all are powered by battery power when the church uses them normally.
We have a gig coming up next week, and I'm expecting to use some mics that require phantom power. Does anyone know if I need to do anything like remove the battery when running them on phantom power? I get the impression that they should "just work", but I really don't want a battery exploding in any microphones on my watch. ![]()
The SM94 switches automatically between battery and phantom, and says so in the manual. I read the PG manual, that wasn't mentioned, but I don't know why it would be different. It just takes a diode . . .
I've got a couple of battery mic's and
the manuals say they switch to the phantom when plugged into XLR voltage. |
I have a pair and I have never had to do anything with the battery, I normally run off phantom power.
GuitarTricks.com instructors page. www.studiotrax.net my toons Brought to you by Dr BadGAS |
I know it's not a Shure mic, but I have an AKG mic that uses power, either from a phantom power source or a removable AA battery.
When using phantom power, they advise taking out the battery. I would recommend doing the same, if at all possible, if phantom power is going to be running to each mic (including dynamic mics that don't need it). I would just be afraid of shorting something. In addition, whenever possible you're generally better off using the phantom power rather than the power form the battery. On most microphones this will yield a larger signal to noise ratio, but I guess you would have to experiment with each type of mic to see if there is a difference, how noticeable it is, and whether it sounds better with or without the battery. -MD |
If there is any uncertainty, I too would reccomend removing the battery.
Dealer for Peluso Microphones, Blue Microphones and CBI cables.... http://www.myspace.com/xstaticstudios |
| Phantom Power on the AudioBuddy | Gilmore89 | The Rack | 4 | 05-18-2006 02:07 |
| phantom power question....mixed mics | kensington | Microphones | 8 | 11-02-2004 08:10 |
| What is the noise floor on your Delta? | canada-paul | Digital Recording & Computers | 30 | 05-27-2003 06:59 |
| phantom power? | timandjes | Microphones | 2 | 03-22-2002 05:42 |
| Phantom Power Question | King Elvis | Microphones | 4 | 03-14-2002 07:40 |
