Old 09-08-2006
jondonbobby jondonbobby is offline
Newbie
jondonbobby has a little shameless behaviour in the past
help with xlr to rca
i just got a audiophile 2496 and the inputs are rca jacks and im trying to connect my compressor to it but the only outputs my compressor has is xlr and the 1/4 outputs,does anyone know a good idea to kook it up?
Old 09-08-2006
misscc803's Avatar
misscc803 misscc803 is offline
Tech Support Specialist
misscc803 has a reputation beyond reputemisscc803 has a reputation beyond reputemisscc803 has a reputation beyond reputemisscc803 has a reputation beyond reputemisscc803 has a reputation beyond reputemisscc803 has a reputation beyond reputemisscc803 has a reputation beyond reputemisscc803 has a reputation beyond reputemisscc803 has a reputation beyond reputemisscc803 has a reputation beyond reputemisscc803 has a reputation beyond repute
You can get an 1/4 to RCA cables see below.
http://www.sweetwater.com/store/detail/CPR110/
Nicole
For Incredible Prices on Music Gear-CLICK HERE!
www.myspace.com/missdjcoleycole
www.soundclick.com/ccproductionsmissdjcoleycole
Tool Box: (Production)
Akai MPC2000
Casio CTK-451(midi controller)
Reason 3.0
Reaper
Records/Ton of samples
Old 09-08-2006
Farview's Avatar
Farview Farview is online now
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
They also make xlr to rca cables, but if you have the 1/4 outputs, just use the cables above.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 09-09-2006
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
or if you make your own....tie low to ground
in other words;
tip to pin 2
ground to pin 1
low to pin 1
or if you want to use 1/4";
RCA tip to tip
RCA sleeve to sleeve of the 1/4"
www.redlabaudio.com
RCA to XLR....impedance loss? Phosphene The Rack 4 01-21-2006 02:48
XLR, RCA, converters va5ja Digital Recording & Computers 8 08-05-2004 09:54
Monitors: XLR, RCA or 1/4"? gotwalp Mixing / Mastering 2 07-08-2004 16:51
XLR to RCA thajeremy Recording Techniques 11 03-29-2004 20:08
Yorkvilles, female RCA to XLR cables? oldboy Microphones 3 03-11-2004 19:07
