Old 09-08-2006
Nick_Black's Avatar
Nick_Black Nick_Black is offline
Mirthmaker
Nick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond repute
EQ position
Hey, i was wondering if I get an external EQ device (currently I'm just using an EQ software program) Should i put it in with a single instroment or should i add it to the total mix down, or should i set it up so i can switch from instroment to instroment? thxs
PS. how important is it for a rack to have a voltage regulator?
Old 09-08-2006
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
I'd submit that if the entire mix needed EQ, there's something that should be addressed at the track level.
(PS) Do you mean a true voltage regulator, or a simple power condidtioner?
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 09-08-2006
Nick_Black's Avatar
Mirthmaker
a true voltage regulator, and thanxs for the EQ tip, so basically your saying i should EQ it before i record right?
thxs
Old 09-08-2006
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
It means it's good to get it right at the track level (preferably with minimum eq where you can) rather than try to fix something after it's in the mix where you would be compromising other things that don't need 'that' eq.
Whether that is done at tracking or at mix time depends a lot on the equipment you have (for tracking vs mixing) and if whether you know what's needed right off or would be better making those calls once you hear it in the mix.
+ or - (more or less)
my listening position is still screwey FALKEN Studio Building & Display 19 02-18-2006 16:47
Lace sensor Gold on the bridge position... James Argo Guitars and Basses 14 12-11-2004 13:31
New recording room with pictures, help me position things! Shakuan Studio Building & Display 19 04-29-2004 11:28
Line 6 POD problems... anyone else? Guitar will not play when in neck position?? pisces7378 Guitars and Basses 11 01-08-2002 00:50
