Mackie 1604 Woes from a newbie, how to do basic routing and more...
First post on this board, have been looking for a studio forum that actually discusses STUDIO EQUIPMENT instead of laptop computers! Glad to find it
![]() I'm new to all this and somewhat confused as to how to do a few things with my Mackie 1604 mixer (not pro-vlz or whichever). First, I'm wondering if there is a way I can send a channel to a compressor or other effect, and have the 'dry' NOT play. For instance if I have a synth on input 1 of my mixer, I can have it "send" out to send1 output to a compressor, and I can receive that back in to the mix too -- but now I have the original synth track, AND the compressed version. I want only one or the other.... should I be achieving this with patchbays instead of through the mixer? Next, I'm wondering how to add a final 'mastering' section to my chain -- EQ and some final compression. My mixer out is basically set up like this: Headphone out -> Stereo, for monitoring Record out -> DAT (tascam da-20 II i believe), for recording This works fine, I can monitor and know what's going to the DAT.. however, I don't see where I can add in any mastering. I also don't really understand how I can master after I've recorded on to my DAT... Thanks in advance for any advice! Robert |
Welcome to the board...
hope that helps.
Dishonest lifelong misspeller and theif... Graphic When Your Horse Dies, Get off It... -David Petrie's tomb stone. |
As far as the mastering, what you'd need to do is run the analog outs from your DAT to the line in jacks on two open channel strips on you mixer, one for left, one for right. Then you can use the AUX sends and insert jacks to chain your outboard mastering processing as needed. HTH, G. |
Mike |
In response to other thread: Multitracking has seemed like it might be the tool for the job, but I don't know anything about it at all. Up for any suggestions.. Thanks, Robert |
G. |
BTW, Mackie does still have the manual for the original 1604 available for viewing and for download online here. That should be a great help for you.
G. |
Apparently the manual gives you information on how to modify the hardware to get the AUX channels to be Post EQ, Pre Fader, Pre Alt/Mute... whereas by default everything is Post Fader (which is why I had the problems I did) Though I'm not bright with studio gear, I am clever with electronics, so tonight I will break open the 1604 and fix this! Great stuff I'm still somewhat fuzzy on the whole concept of Insert jacks and how this postprocessing chain would work out, but I'll simply get one of those cables and play around to learn. Thanks very much, Robert |
as a side note I think this is a good example of "there's more than one way to skin a cat." It's all about what works best for ya. (After you know what you're doing of course)
An insert jack basically taps into the channel signal - typically post input trim, pre-just-about-everything-else, but you'll want to check that in the 1604 manual (I'm used to working with the VLZ, which does have signifigant differences). This tap actually interrupts and detours the signal flow to the external device(s). It's just like "inserting" your compressor (or whatever) into the middle of the channel strip. But if you take a standard balanced cable and only plug it into the first "click" instead of all the way in to the second click. It allows you to tap the channel strip signal without actually interrupting and detouring it. This way you can send a "copy" (so to speak) of the signal to your outboard compressor yet also allow the original signal to contunue on through the channel strip unimpeded. Instead of virtually "inserting" the external chain into the channel's signal flow, you are now just splitting the signal like a "Y", where you have it going into the channel strip clean and uninterrupted, *and* out to the processing chain on a seperate line. Using that second "one click" method, you can then take your processing chain as a tap off of dry cannel 1 and return it to a different channel as the wet processed version, just like you asked. The manual for the VLZ (also available on the Mackie website) has a nice and easy diagram of this method. I'm not sure if the one for the original 1604 does or not. G. |
Now the sends are pre-fader, all is well and I am successfully routing my FX just how I'd like! A big thanks to everyone here who lent their assistance
I took a couple pictures of the finished job, it actually turned in to a LOT more work than I initially thought it would... but there's nothing wrong with some quality "behind the scenes" time with my hardware ![]() Thanks, Robert Full Board View Close up of some channels |
