re-amp question
i use a mackie onyx 1620 with firewire as my interface, and it only draws one stereo signal from the computer. i want to get into re-amping and the way i had it figured i would have to have at least one more output to run to the amp in order to hear the re-amped signal and the rest of the song at the same time. - i would use the stereo out from the mackie to play the rest of the song and run the dry guitar signal out seperatley, into the re-amp box then to the amp - and mic it. i was just wondering if i had it figured right - and if so, what peice of gear people might suggest to get some more analog outputs from my DAW.
i was also curious if anyone had experiance re-amping from tape - i have an otari mx5050 1/2" 8-track as well thanks, ben |
My advice would be to mute everything but the guitar you wanna re-amp, take the guitar from the mackie out to the amp, and mic it back to the mackie.
In the end, you are just re-amping, you don't need to hear the song again as if you were playing. |
thanks for the response. the reason i wanted to hear it in context would be to adjust the tone on the amp, mic placement, stomp boxes i might use, etc.. So i wanted to hear the re-amped guitar tone with the song.
I've done it from tape. For clean tones, you can get away with it. For distorted tones, the tape hiss becomes a problem.
| New Tube Amp - Stupid Question | gvarko | Guitars and Basses | 40 | 04-04-2006 13:50 |
| ROG-type amp design question | GreenDank | Keyboards and Sound Modules | 1 | 01-13-2006 08:48 |
| amp question? | dkimcohn | Recording Techniques | 2 | 12-26-2005 21:56 |
| Power amp question | Kevin Deschwazi | Mixing / Mastering | 3 | 04-02-2004 18:02 |
| recording live guitar amp question & Br-8 | katmandude | Roland, Boss, VS Series Forum | 2 | 08-22-2001 10:09 |
