Alesis Multimix8 and PC req'ments
I am a newbie to home recording. Very interested in purchasing the Multimix8. I am looking for info regarding pc requirements, specifically:
1. Firewire connection (through standard PCI firewire)? 2. Soundcard requirements (if any). I want to output to monitor speakers (not typical pc speakers). So is this monitor output from the soundcard or from the mixer? 3. Hard drive requirements: What are people using for hard drive in terms of speed, access time, etc? oh yea, I guess I will start out with the Cubase LE bundled edition, I shouldn't need more than 4 sim. inputs for now. Thank you for any help you can give. |
I bought the Multimix8 FW in March. It is connected my my "modified" Dell 4700
Pentium 4 2.99 Ghz 2 G of ram running XP. The appears to be more than enough to power the multimix. I believe it is recomended to use the Multimix as your only sound card. I'm sure a hard drive needs to be as fast as possible. I didn't check, but I would think these specs would be on the Alesis web page. By the way be sure to download the latest drivers and read the manual. I on occasion still "lose" the multimix and have to reinstall the drivers. Good luck! |
Thank you for the advice. So the only connection you have is the firewire?
And do you use the mixer for monitor outs? thanks again. |
The firewire cable connects from you rmixer to your computer, your computer needs a firewire card, most PC's already have built in firewire ports. I build my computer for recording so I used a MOther Board that was recommended by others. |
From the Alesis Site:
"Windows: Windows XP Service Pack 1 or higher (Windows Installer 3.1 component from .NET required) 1 gig Pentium processor or higher 256 Megs RAM (512 or higher preferred) 4,200 RPM hard drive for basic recording (5,400 or higher preferred for multi-track recording and playback)" I think this are the specs for a laptop since most laptops are equiped with slower Hard Drives.[4200 rpms/5400 rpm's] The recomended Hard Drive for recording is a 7200 RPM Hard Drive. |
Thank you, that clears up all the confusion.
Great Site!! |
Is the a big difference between the USB version and the FireWire version?
i dont own one of these (yet) but i think the usb ones can only stream a stereo signal to or from your computer, but the firewire ones stream all the tracks and sends and everything.
