Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 09-05-2006
darkecho darkecho is offline
Dedicated Member
darkecho has a reputation beyond reputedarkecho has a reputation beyond reputedarkecho has a reputation beyond reputedarkecho has a reputation beyond reputedarkecho has a reputation beyond reputedarkecho has a reputation beyond reputedarkecho has a reputation beyond reputedarkecho has a reputation beyond reputedarkecho has a reputation beyond reputedarkecho has a reputation beyond reputedarkecho has a reputation beyond repute
Minimalist Mic Setup with Triggered BassDrum?
I was reading the old thread on using two overheads to get a "phat sound" but In my particular situation, my drummer has triggers and he does the best he can to mute the bass drum.. This effectively takes the bass drum out of the equation, as far as phase cancellation and miking that is...
so my question is, what would you guys do to get the best sound out of say two over heads and a couple of 57s with a triggered set?
I was thinking of using the same method that tubedude used but not measure from the bassdrum.
Old 09-05-2006
Ironklad Audio Ironklad Audio is offline
1K Silver Member
Ironklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond repute
throw a 57 above and below the snare, then set up the OH's however you see fit
Old 09-05-2006
guhlenn's Avatar
guhlenn guhlenn is offline
Oh REALLY????
guhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond repute
and a sm 57 on hi-hatt.
G.
I'll be succesfull tomorrow.
too busy on the forum today...
Old 09-06-2006
Dedicated Member
will the OHs pickup the toms good enough?
and a 57 on the highhat??
I have a delta 44, so I will have the two OHs going into my preamp and then into the delta taking up 2 of the 4 spots, then a snare track would get third and then the triggered bassdrum would get 1..
so i would have to sum anything else with one of those signals...
unless i recorded the OHs into one signal as stereo or something?
Old 09-06-2006
guhlenn's Avatar
Oh REALLY????
stereo is two track. the 4-track limitation makes it sdman easy; triggered kick, 2xOH and sm57 on snare., you dontl; have capacity for more
a 'triggered' set to me suggests triggered toms. but i was wrong. the OH will pick uo toms, but for my taste to little. But placement can fix that. I think. Just experiment, what's there to lose?
G.
Old 09-06-2006
Dedicated Member
well, since you ask... there is LOTS of time to lose, some electricity... maybe some fingers... friends... if you are in the building, which is the target of an asteroid, you may lose your life, and all of your equiptment.. so i guess there is lots to lose, but probably nothing but time....
eventually my drummer wants to get triggered toms, which would be wonderful.
hell, maybe he should just get an electric drumset......
wouldnt that be a joy to "record"
Old 09-06-2006
Dedicated Member
also, i have a mixer available...
but i would have to combine signals... what would be best to combine the toms with? snare? or bassdrum? cause i am using my 2 channel BG for the condensors (i figure that they can take more advantage of the $$$ preamp)
the sm57 will go through a behringer mixer, and the bass drum trigger would just output to my delta, with no middle man (drum brains do not need to be preamped, right?)
Old 09-06-2006
Dedicated Member
and if you wanted to get that placement ability for the toms, you'd need to mic each one seperately so you could pan them around to make it sound like they go across the board right? so I think maybe I will just leave the toms in the OH recording...
should the OHs be recorded in stereo? or as two mono signals (one signal for each mic) and then pan them seperately to taste?
Old 09-06-2006
1K Silver Member
two mono signals combined into a L/R IS stereo!
but yea, throw 2 mics up for the OH's, play around with their placement to get the spread of cymbals and the tom hits to sound like you want them to...or at least as close as possible
Old 09-06-2006
Dedicated Member
well, i have the option of recording into an actual STEREO channel, where the program combines the two into a single stereo track. or i can record to two seperate tracks and adjust volume and pan of each of the two signals independantly...
Old 09-06-2006
guitarboi89 guitarboi89 is offline
Dedicated Member
guitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond repute
seperate channels so u can control how wide the overheads are
im actually testing out the same idea cause i cant afford a kick mic
  #12
Old 09-07-2006
guhlenn's Avatar
Oh REALLY????
stereo is the same as two mono channels, but stereo has some limitations while mixing. I would definately put the snare trough the BG, as that will be thloudest in the mix. OH's usually are softer anyway. What you could do (i;v done this) is mic the toms seperately, pan the channels, and then combine em with your overheads. You need to be REALLY sure your levels are ok and that you liek the sound/panning and stuff, but that could work. otherwise, just use the OH's and place your mics so they pick up more tom then cymbal. Hell, who likes cymbals anyway? well drummers do. but then, they are drummers.
G.
  #13
Old 09-07-2006
Dedicated Member
so you are saying that I shoul put both of the OH into the behringer and then into two seperate tracks, then put the snare through the BG? then i am wasting a BG input!!!
why not have the two OHs into the BG and the snare through the mixer?
  #14
Old 09-07-2006
guhlenn's Avatar
Oh REALLY????
Yup, i know. the reason for this is simple. Take your favorite cd, and listen to it. somewhere in the back you'll find you hear some cymbals. and way up front you'll find the snare. The snare will eb heard in detail, the OH's not. so your money preamp (heh) will be heard.
But try both, but then i wouldn;t sum the signals with the berry, just run the OH's through the BG and sum snare and toms through the berry.
and report back ofcourse
G.
  #15
Old 09-07-2006
Dedicated Member
ok. so now my question is, where do the toms need to be in the mix? up front and loud with the snare? or back with the cymbals?
the answer to this will finish my decision, if the toms need to be up front and loud, then I will have the toms and snare go to the BG and into the Delta44 as seperate tracks, the Bass drum triggers get their own input, leaving one input for the OHs, (which means i will have to combine them in the mixer as one track so i would lose the ability to adjust the volume of either side or to pan them around..)
if the toms can be quiet, I will just let the OHs pick them up, and each OH mic wil have its own track out of the mixer, the snare will go through the BG into an input and the BD will get one.
I am thinking maybe I will just leave the toms unmiked... just for simplicity sake...
  #16
Old 09-08-2006
guhlenn's Avatar
Oh REALLY????
you are joking right?
that's like the little bit of artisitic freedom you have, and imho the joy of mixing. I would mic and mix at the spot i guess. i like my toms loud and in stereo, and the OH soft and in stereo. mono drums don;t work for me. or my talent needs them to be in stereo
G.
  #17
Old 09-08-2006
Dedicated Member
well the ohs will be in stereo... the snare will be put slightly off center, but for simplicity's sake, (and because I am doing this particular recording as a favor to a friends band) so I sort of want to just produce something useable (myspace and handout CD demos). I dont want to go nuts on it because i dont want to spend that much time
so I think I will just adjust the mics to pick up more of the toms and then the OHs will have the toms and cymbals in stereo...
then i can take those two signals and pan them however wide or narrow i want them. but the toms and cymbals will be stereo
then il take your advice and put the snare through the $$preamp.
I will report back, this will take place probably monday of next week
plus, the less mics i have to worry about, the less problems i will have with phase cancellation.
  #18
Old 09-08-2006
TragikRemix's Avatar
TragikRemix TragikRemix is offline
I am NOT a Gear Whore. ;)
TragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond repute
here's what a start with right off the bat when it comes to a drum mix-
-Pan OH's All the Way left and right.
-Lower OH fader down halfway.
-Pan Snare 15-left
-EQ kick and snare, taking out 500hz completely.
Thats my starting point. where i finish, i'll never know. adjust to taste after that. compression etc, more fun here and there.
not saying that will work for you! It DOESNT work for me, but i think of it as a nice, constant starting point, and it's what i always start at.
geez. first you want to know how to setup the mics, now you want to know how to mix them too!....
GFCG Member: 000 029
F**k Your Scene.
  #19
Old 09-09-2006
Dedicated Member
im a data sponge thansk for the responses, they will definately be helpful.. now I just need to get over to the practice space and work on mic placement.
  #20
Old 09-09-2006
BigRay's Avatar
BigRay BigRay is offline
I hate jambands.
Location: Southeastern NC. No more Krauts and Bad music.
BigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond repute
go to http://www.electrical.com/ and look up Steve Albini's technique..his thinking is that noone ever hears drums from over head on a CD, so why mic them that way? Steve is a genius!
  #21
Old 09-11-2006
guhlenn's Avatar
Oh REALLY????
do you have a link. searched but can;t find it. interested though... as it is, logical
G.
  #22
Old 09-11-2006
Dedicated Member
indeed it is... how else would you mic them? technically, in this frame of thought, you would want to mic everything from an audience point of view.... so everything should be miked from a signal focal point.
  #23
Old 09-11-2006
guhlenn's Avatar
Oh REALLY????
binaural recording... it exists, but u wonder why it isn't common practice...
G.
  #24
Old 09-14-2006
Dedicated Member
if you recorded binauraly you would probably be forced to introduce a lot more room noise..
  #25
Old 09-14-2006
tnjazz tnjazz is offline
Force of Nature
tnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond repute
-Pan Snare 15-left
Why would you pan the snare? It's likely to be the driving force of the track right? You want that right up the middle I would think. Off center snares bother me for some reason.
My starting point for panning is typically representative of the kit and the mics. OH panned all the way usually makes it sound too wide. You don't want mono drums, but you also don't want the drummer playing a kit that's 30 feet wide in the headphones!
Just my little bit of input. Mix however you like, of course.
Ribbon Mics With/Without Phantom Power... kidvybes Microphones 16 08-26-2006 12:35
Advice On Recording Vocals! rnb259 DJ & Hip Hop Production 8 04-28-2006 13:31
Help: Mic Decisions and My Trip to Guitar Center JohnnyMan Microphones 61 04-16-2006 22:38
The Mic Test Thread! Rhythmschism Microphones 41 04-30-2004 12:23
mic setup for live/in my attic recording platinumcool Recording Techniques 0 11-14-2002 09:20
