I spend a lot of time slowing down guitar solos. Sometimes when I apply a time stretch to a segment, the segment will double in length (as it should) and half of the segment will be highlighted. But on playback there's a hiccup (a microsecond is repeated) right in the middle. I'm not running any other programs, and I have only two other tracks which are archived to reduce overhead.
Has anyone else run into this? |
Zimm - I assume you are doing this to learn the solo. Time stretch is always a bit wonky as it takes some pretty heavy calculations. Why not try using Prosoniq Time Factory to do it. It is not a pluggin but will do it perfectly without glitches.
cheers John |
stretch stretch again
Even though I'm an ardent Cakewalk fan, time stretching as well as pitch control has been a major failure for cakewalk.
It has never done the right job for me. So, until they improve this feature (and I hope is soon) I've opted for sound forge which has done a wonderful job for me. It communicates with Cakewalk perfectly an you can use the best of both worlds. I think if you -use time stretch often you should consider investing in time forge. I think it will be worth it. stretch and pitch !! wari |
Thank you
I'll look into those software recommendations.
Thank you for your replies. |
