Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
  #26
Old 06-11-2007
travelin travis travelin travis is offline
Banned
travelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond repute
to get started with impulses just load a impulse file in sir or reaverb and route a track thru it. you can get impulse files from noisevault.
  #27
Old 06-12-2007
Sonixx's Avatar
Sonixx Sonixx is offline
1K Silver Member
Sonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond repute
Originally Posted by ggunn
Can you recommend a tutorial site where one can learn about impulse files, what they are and how they can be used?
I'm Keiffer... and thanks
I used Voxengo's Deconvolver.
It's very simple, run a Ramping Frequency thru an amp and record the output. Then use Deconvolver or equivalent to create the impulse. I used the output section of my 5150 as the amp. Deconvolver includes the ramping frequency.
Check Voxengo's Deconvolver Documentation.
Also, check Andy Sneap's Forum at UtlimateMetal.com. There's several very good Impulses there.
Clips...
  #28
Old 06-12-2007
ggunn ggunn is offline
Crystal Flavolian
ggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond repute
Thanks, but can you get a bit more basic than that for me? Exactly what is an impulse file and what use is it?
Gordon in Austin
http://www.crystalflavola.com
  #29
Old 06-12-2007
metalhead28's Avatar
metalhead28 metalhead28 is offline
Hates Raymond
metalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond repute
An impulse file is the sonic signature of a space or piece of gear. You generate an impulse by feeding a short sample through the gear or into the space and recording the resultant output. Then you basically subtract the original sound and you have the impulse.
Impulses are used with convolution plug-ins. The convolution plug-in actually merges or multiplies the impulse you select to a dry audio track, thereby imparting that sonic signature to the sound. Those are generally associated with reverb, because using an impulse response from a real space is so realistic sounding.
Naturally, this technology has spilled over into capturing impulses from vintage gear, micing guitar cabs, etc. It's pretty damn impressive.
So in the case of Sinixx's impulses, you record a dry DI from your guitar (using the pre-amp out of an amp, or whatever) and then use a convolution plugin with one of the mic'd cab impulses, and your DI track will sound like it was recorded with a mic in front of a cab instead.
There are lots of convolution plugins on the market these days. I use "Perfect Space" which is bundled with Sonar.
Some of my music
STINNETT GUITARS
  #30
Old 12-13-2007
mikko/boogie mikko/boogie is offline
Registered User
mikko/boogie is on a distinguished road
go to guitarampmodeling dot com and look under impulses. You can also find a load of impulses there. Can't post urls yet since I'm new here...
  #31
Old 02-19-2008
tba03 tba03 is offline
Registered User
tba03 is on a distinguished road
are those impulses still available somewhere?
Bookmarks
Isolating a Guitar Cab David Katauskas Recording Techniques 12 08-11-2005 17:17
Bass head through guitar cab gitrguy87 Guitars and Basses 2 07-10-2005 22:42
Guitar head / cabinet impedence issues...please help! copperandstars Guitars and Basses 12 06-22-2004 09:34
Guitar Cab mic :Sennheiser e 609 Silver vs Studio Project B1 Simmons Microphones 0 10-29-2003 07:32
PA Amp Head for pushing a guitar cab?? Trippalot Guitars and Basses 6 04-23-2002 08:20
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 1995-2010 Audiofanzine except where noted. All Rights Reserved.
