Trying to record with a Casio CTK-691 keyboard
This is a $200 or so keyboard with some reasonably nice piano and organ voices on it that I'm trying to record with using my M-Audio 2496 soundcard, the only audio out it has is a "Phones/output" jack on the back, but despite trying many things (including putting it directly into the soundcard and putting it through a mixer (cheapo behringer one)) the recorded sound is nothing like as nice as the sound that comes out of it's built-in speakers, so, ridiculous as it might sound, I'm about to try and mike one of them up with an SM57 (the only mike I own) to see if that sounds any better. Can anyone suggest anything else I could try, or explain why the sound from the Phones/output socket is so crap (the manual doesn't say much about the Phones/output socket apart from "When connecting to a musical instrument amplifier, set the volume of the keyboard to a relatively low level and make output volume adjustments using the amplifier's controls")
My guess is that the sound coming out of your headphone jack is stereo and you need an adapter plug (going into your headphone jack on one end) that will have two (left and right) plugs (on the opposite end). You will have to record both (left and right) channels at once to get the stereo sound.
does it have MIDI .. you might be better off with some free vsti's from
http://www.kvraudio.com/ youll probably get better sounds.. otherwise the stereo adapter might help... and the sm57 should get a decent sound out of the speakers (adjust angle and position for tone) gl |
Edit: I miked up one of the speakers, and while it sounded much better than what I got when I use the headphone out socket, it was very quiet, even with the gain turned right up on the mixer, so it looks like I'll probably have to have the speakers on the Casio really blasting to get a decent level on any recordings I make. Meh. Last edited by Mr songwriter; 08-30-2006 at 14:13.. |
What you are probably doing is messing with the stereo digital effects. They are in stereo when you play the keyboard using it's own speakers but you're probably recording it in mono or doing something else in the process of trying to record it that's disturbing the stereo field.
At best you are losing the stereo nature of the effects and at worst causing serious phase problems that can rob a sound of bass from the midrange on down. .
...now in HD. |
A thought...does your keyboard sound good when you listen to it through decent headphones?...If it does you can probably rule out the keyboard/headphone jack as the problem and work your way on down the recording chain.
| Korg i5M - 'extra' tracks won't record | Tubedriver | Keyboards and Sound Modules | 0 | 06-18-2001 02:45 |
| 2 Qs: lecture recording and video record (analog) | asf131 | Newbies | 7 | 11-20-2000 20:17 |
| I need a decent keyboard, what you guys recommend? | musicmaker | Keyboards and Sound Modules | 4 | 09-23-2000 19:42 |
| I need a keyboard which can record sample, what brand recommend? | musicmaker | Keyboards and Sound Modules | 0 | 09-21-2000 13:03 |
