Old 08-29-2006
mixmkr's Avatar
mixmkr mixmkr is offline
we don't need rest!!
mixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond repute
yet another insulation question...
but this is about insulating properties for heating and cooling...not sound.
I want to add some extra insulation in my attic...say another R30 or so, ... on top of my measly (estimated) R19 that is already there. I am either thinking about just adding some more unfaced bats perpendicular to my ceiling joists (my current insulation comes to the top of them) OR blowing in some of this cellulose stuff. The only arguments I hear against the "blow in" stuff is that it settles. Otherwise it has some other advantages, not to mention MUCH cheaper and MUCH easier to do in my case.
So, should I pony up the extra $600 bucks or so for the fiberglass rolls to cover my 2000 sq ft. Not to mention having to lug up all these rolls of insulation up some attic steps and then struggle to roll them out (basically sounds like a miserable day) .... or just rent a machine and blow it in myself (or hire it out.. not much more actually)?
btw, my plans are to put a couple of rolls near my soffits, along the edge of the roof, so I don't blow the stuff in and cover my soffit vents...without having to install baffles and excessive crawling around....and maybe a roll down the center line should I need up there again for some odd reason to run more wiring.
Old 08-29-2006
seismetr0n's Avatar
seismetr0n seismetr0n is offline
face melting 6string fury
seismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond repute
definately go with the cellulose....
not only is fiberglass a toxic devil (feel itchy)
but cellulose has about twice the insulating properties.. and is way easier to install = spray gun/tube
id recommend the baffles (plastic/foam) in your eaves .. just so you dont have to deal with fiberglass.. youre going to have to get over there one way or another... just put them over your planned line of insulation and try not to fill them if you blow it yourself...
for a walk path build a plywood U to hold out the fiberglass.. but wide enough to crawl on...
the fun part will be for whoever remodels in 20-30 years
contractor by day/home recorder by night
seismetr0n
Old 08-31-2006
seismetr0n's Avatar
i cant edit.. (for some reason).. but it should say
"build a plywood U to hold out the cellulose"
Question about monitoring. someguy211 Newbies 4 08-24-2006 21:48
NY Times article on home recording and soundproofing AlChuck Studio Building & Display 18 04-06-2004 16:46
Insulation Question DDev Studio Building & Display 2 10-31-2002 12:52
Question about Acoustic Insulation ob Studio Building & Display 4 08-16-2002 13:11
Insulation Thickness Question For Absorbers ram3n Studio Building & Display 8 08-13-2002 10:44
