Old 08-26-2006
Spillenger Spillenger is offline
Newbie
Spillenger is on a distinguished road
Why Am I Getting a Signal?
Normally, we post a question when we DON'T get a signal, but I am having a perplexing problem -- I am getting a signal when all my levels are at zero.
I am recording with an E-MU 1820m into Sonar 4 running on a Dell PC. I'm using an Audio Technica AT2020 mic running off phantom power. Let's forget Sonar and the PC for a moment. When I turn everything down to zero -- my gain on the "A" Mic/Line on the breakout box, and the sliders on the PatchMix software control panel -- I still am somehow getting signal into the 1820m! I see the little green light on the breakout box lighting up, and I see the meter on my Mic/Line A in the control panel hitting up to about the 3/4 mark.
How can this be? I'm used to no signal getting to the sound card when everything is zeroed out like this.
Why is this a problem? Because clearly there is something I'm not understanding about how this setup works. And I suspect it could affect the quality of my recordings.
Any explanation much appreciated.
Paul S.
Old 08-26-2006
Halion's Avatar
Halion Halion is offline
1K Silver Member
Halion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond repute
The most logical answer would be that something is broken. Maybe a noisy component in your mic causing strange spikes (perhaps in unhearable frequency ranges?) or some kind of grounding issue?
Old 08-28-2006
DrJones's Avatar
DrJones DrJones is offline
Senior Member
DrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond repute
I generally have this problem when I run Live sound. What is happinig is your input signal (PFL) is to hot. Either change Mic position or use a DB pad.
-Jones
MY Studio Pics Here http://myspace.com/piperstudio
* "You can only polish a turd so shiny" *
Old 08-29-2006
tangerine's Avatar
tangerine tangerine is offline
grumpy bastard
tangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond repute
Sounds like it could be system noise from the PC, check that the graphics card is not in the slot next to the sound card, this can cause noise to register on your volume meters. You could try double clicking on the speaker icon in the systray or open up the soundcard control panel and mute the CD playback. I have had this problem with this steam driven thing I have at home and this works for me. GOOD LUCK
I give espskully the splats
Is a soft signal of less quality than a loud signal? nononsense! Mixing / Mastering 14 08-29-2006 14:05
My home recording studio ideas. Here's the scoop. SMX_Dizzy Recording Techniques 121 01-05-2006 22:56
converting AB to MS FALKEN Microphones 8 07-19-2005 09:32
playback signal is being recorded with my live signal jmxdrummer Cakewalk / Sonar Forum 1 06-29-2005 19:33
My God, a stunning thing happened. jeff0633 The Rack 39 05-02-2005 09:18
