How do I set my gain structure??
Hi there-
I have a guitar rig that I have had for awile, but I am a little confused about all the different in/out gain settings. What I really want to know is, is there a general rule to follow when setting things up. For example, is it better to crank up the output on the power amp and use the pre amp as a master volume, or is it better to crank up the pre amp and use the power amp as a master volume, oooorrr keep them about the same? I've fiddled with it but can't seem to come to a conclusion as to what is better. The only real noticable difference that I can tell is that when the power amp is creanked up, there is more noticable noise (hiss). I am using my rig only for recording so I don't need massive volumes. But I would like to benefit as much as possible from the tubes in my amp, that is why I keep the the amp levels up. Am I even going about this the right way? |
Thanks, I'll try that!
| Gain and mixing | StylusEpix | Newbies | 4 | 01-14-2005 20:56 |
| No makeup Gain on comp.... | turnitdown | The Rack | 9 | 06-28-2004 16:24 |
| The Mic Test Thread! | Rhythmschism | Microphones | 41 | 04-30-2004 12:23 |
| Live Mixing Problems... | MiXit-G | Mixing / Mastering | 11 | 04-07-2003 05:17 |
| Preamp input gain problem? | muser | Microphones | 3 | 02-01-2003 13:20 |
