chorus for bass?
i know this has always been a sort of "classic" mixing technique, or at least i've heard it mentioned before, but i was wondering if many of you guys actually use it in say a 4 peice rock group configuration. i tried it out and i think i like it, but it just takes getting used to. so either i need some support or some advice to tell me when you think it is a good idea to use it. i do like the way it allows the bass a new place in the mix.
tascam 1804 self-built amd 4000+ system gateway m285-e core 2 duo tablet pc m audio sp-5b's reaper v1.8x |
I use it sometimes...just a different flavor. If you likey...keepy.
SoundClick...geezer stuff [Acoustic Rock] MySpace...enter at your own risk. [Metal Oriented] |
Yup...I use it at times. Sometimes it fits sweet. Just depends on what the tune calls for. If you like it, go for it.
I love the sound of a chorus on a bass. Early Pearl Jam is a great example. I think Jeff Ament even had a fretless bass on a lot of that stuff too. AWESOME TONE!
"Thank you, good bye, and better luck next time" http://www.myspace.com/robertsred |
Just be careful
it's really easy to overuse it. When it's off, then you feel like something's missing. I guess it's all up to personal taste, though.
ÜNTZ-ÜNTZ-ÜNTZ Cyanide-Dependency www.myspace.com/cyanidedependency www.cyanidedependency.com "I think vaginas are pretty disgusting and sort of resemble an angry sea anenome without the nice smell." -sweetnubs |
Chorus on bass really is something to be careful with. The phasing will cause vallys and peaks in the notes. It will help the bass seem more dynamic in interesting because of the special effect.
To get around some of the bad effects of chorus on bass, you'll want to use parallel processing. Get the dry signal and split it into 2-buses, or 2 tracks. On the seperate buses, have one high passes at 150hz, and the other low passed at 150hz. The track that has been high passed is the one that'll have chorus applied. THe low passed bus will stay dry. Then you can sum the buses to a new bus. Or keep them seperate and mix to taste. This will keep the low end coherent and solid. Your basslines won't drop out because of the phasing of chorus effect. This way you can use stereo chorus and you don't have to worrk about stereo phasing problems of the low frequencies either. |
| Getting chorus effect on acoustic guitar | Ricklh | Guitars and Basses | 6 | 10-05-2003 03:58 |
| Okay, you songwriters...feedback | Greenshoe | Songwriting, Singing & Vocals | 20 | 08-13-2003 13:11 |
| Chorus effect to a mix | Jack Real | Mixing / Mastering | 9 | 05-30-2003 06:57 |
| Can't get rid of chorus effect on SB Live! card | gilwe | Digital Recording & Computers | 2 | 03-21-2002 11:24 |
